Bolzoni Auramo RC-F Rotators for the aluminium creation process Scroll down for video
- 27 Jan 2022 ( #1061 )
Bolzoni has recently delivered more than 70 rotator units, model RC-F, designed for foundry applications in the metal industry. The units have been delivered to a leading producer of aluminum, who has 43 factories in 5 continents and a large need to rotate and to empty containers with melted metals.
The foundry processing cycles are extremely challenging and require robust material handling equipment.
This Russian group counts on its own resource base, carrying out the entire production cycle from the bauxite extraction to the production of finished goods, such as billets, wire rods and car wheels. The yearly output is of about 3700 million tons of aluminium.
Aluminium: one element, many applications
How much is aluminium applied in our everyday life? With features like lightness, excellent corrosion resistance and high conductivity, it is suitable in many fields of application, like consumer good production, packaging, construction, automotive and many more, and to create a large spectrum of objects, from cans to more complex ones, such as aerospace components.
The foundry execution revolving carriage, model RC-F, with motor protection and closed front window to protect hydraulic hoses.
A green footprint is possible
Although aluminium can be reused and endlessly recycled, the energy consumption required to carry out the production cycles is remarkably high. In order to reduce to the minimum the CO2 emissions, this Bolzoni customer is committed to produce aluminium using 90% of renewable hydroelectric power. This is a great green example to follow.
RC-F rotator: special execution for foundry
The foundry environment and processing cycles are extremely challenging: the handling and emptying of containers with molten metals in safe conditions require robust material handling equipment, resistant to high temperatures and designed for heavy-duty applications.
Besides its robust features, the foundry RC-F Series rotator is specifically equipped with a special steel plate, to protect the rotator motor and hoses. The rotating device rubber ring is protected and insulated to prevent any dirt penetration.
The revolving carriage is suitable for all applications where working cycles require load rotation or emptying of boxes and containers.
Rotating function
With the 360-degree rotation feature, the revolving carriage is suitable for all applications where working cycles require load rotation or emptying of boxes and containers. Here are the main technical features of the Bolzoni Auramo revolving carriages:
  • 360-degree rotation with ISO-2328 fork carriage for continuous rotation in both ways;
  • Specially engineered fork carriage for easy and fast positioning;
  • New fork fixing system guarantees safe, easy and fast forks mounting and positioning;
  • Fast and high-torque rotation;
  • Double scraper to protect the bearing.
As an option, the unit can be equipped with a side support fork arm, to hold bins and containers in the upper part during rotation. The unit is available also for application in corrosive environments, with special zinc-based painting; for example for the fishery industry.
Here the rotator in the fishery version, used in corrosive environments, to rotate or to empty boxes or containers.
Rotating Carriage Foundry Appliacation - RC F
For more information about rotating carriages and to ask for a consultancy on your specific material handling application, get in touch with our Sales Engineers to find out about our references and implemented solutions in the several industrial sectors, such as the Automotive Industry, Logistics and Warehousing, or to organize a demo unit at your facilities. For more information on BOLZONI AURAMO and MEYER products, please visit our website www.bolzonigroup.com and contact us by email, or contact the nearest BOLZONI AURAMO and MEYER representative.
Bolzoni Auramo and Meyer are Bolzoni Group brands.
Bolzoni is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers, covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
