Smart solutions for KOOI®REACHFORKS reduce damage & improve handling speed
- 20 May 2021 ( #1026 )
KOOI®REACHCONTROL - Less damage when moving pallets.
A common problem in organisations where several different pallet sizes are used, for example in the packaging, paper, beverage, and furniture industries, is that it is hard to find the optimum length of forklift forks because they are either too long or too short. If the forks are too long, they will protrude through the rear of the pallet when they are being inserted into it and catch any load located behind it when they are raised. This will damage the pallet and possibly the product, and in the worst case, someone could get injured.
Meijer Handling Solutions introduced its KOOI®ReachControl; a system that includes a flowmeter (base unit 100x80x60 mm and an app to operate the system. This flowmeter can detect the amount of oil flowing through the reach forks. Specially developed software can be read using an app that is compatible with standard Android or iOS smartphones. The more extensive version of the KOOI® ReachControl features the ability to stop the outer sleeves at certain set lengths (at least 8 pre-sets).
Customers can enter the variables themselves and allocate a specific name to each setting. The system can be mounted on any telescopic fork as no modifications to the reach forks are required.
Without the automatic stop function, the system can be rapidly installed and information is transmitted by means of a Bluetooth® signal.
The auto-stop system features a special valve. In addition, a power supply is required because otherwise the battery in the KOOI® ReachControl would run down too quickly.
Although the app can be downloaded to any modern smartphone (iOS/Android), Meijer Handling Solutions recommends purchasing the specially developed 5" colour monitor because this can be connected to an external power supply and features a sturdy casing.
KOOI®Deflection system is a smart device that helps the forklift driver to level the forks horizontally. It is extremely useful for applications such as double-deep pallet storage. If a load is moved forward with a reach attachment like telescopic forks or a pantograph, it will show the entire tilt. Means, it includes the deflection of the attachment, mast and even the compression of the tires.
The forklift driver often has no idea how much this deflection is, because this operation takes place out of sight of the driver. The sensor in the KOOI®Deflection system informs the driver how much deflection must be compensated by the tilting function of the forklift (mast or fork carriage tilt). In this way a safe working method is created and the load remains horizontal on the pallet, thereby preventing damage to pallets, rack and/or decking material. The tilt indicator can also help improve handling cycle time by allowing the lift truck operator to work faster as the operator always know if the forks are level prior to entering into the pallet.
KOOI®Deflection system is a small sensor which is mounted completely inside the nose of the telescopic forks. Because it is completely enclosed in the front of the KOOI®ReachForks, the sensor cannot be damaged and shows the maximum deflection. The sensor works via Bluetooth® and can easily be replaced if necessary.
The sensor can also be integrated into standard lift truck forks, but only on request because the position and strength have to be calculated.
The KOOI®ReachControl is already available and the KOOI®Deflection system will be launched very soon and will make use of the same app.
MEIJER HANDLING SOLUTIONS
www.meijer-handling-solutions.com
Social Media: Facebook | Twitter | YouTube
