Hydraulic Hand Pallet Truck from CJLIFT
- 13 May 2021 ( #1025 )
CJLIFT can offer you a full range of warehouse storage equipment to solve your material handling needs.
CJLIFT Hand Pallet truck is the logical choice for everyday use throughout your operation. Our trucks are designed for easy maintenance with multiple configurations and a wide range of product features and options to meet your performance needs.
Product Advantages
  1. Quick down key function, high efficiency pump to reach the maximum height in less time, which makes it more efficient and labor saving.
  2. Key parts galvanized ensures long services life, stability as low noise.
  3. Unique design strengthened fork frame and customized plastic powder is used on the fork surface, with high surface abrasion resistance, which makes it more durable than ever.
  4. Reinforced four ribs design under the supporting frame provides higher strength, ensures a premium, robust and durable pallet truck, the bearing capacity is strengthened by 25%.
  5. The "C"-shaped groove structure at the top cover, the design of the fork legs and the backrest with the compression ribs are more reasonable and the strength is more reliable.
  6. Compact appearance, complete forged rocker arm, ensure the whole truck evenly pressed.
  7. Integrated pump without welding, no any leaking problems.
  8. Top quality seals, which prolong the working time of hydraulic unit. No routine maintenance at all is needed on the hydraulic unit and bearings.
  9. The oil pump piston rod adopts high frequency heat treatment chrome plating process, with high strength, wear resistance and corrosion resistance characteristics.
  10. Fill the oil pump with low-condensing hydraulic oil, and work as usual at minus 20°.
  11. Various optional of fork width and length suit for different pallet sizes and working requirements.
  12. Optional coating material like PU, Nylon and Rubber etc. for rollers and wheels meet different needs of customer and working ground and conditions.
Product Specifications
Product Hydraulic Hand Pallet Truck
Manufacturer CJLIFT
Model BF20BF25BF30
Rated CapacityQ(kg)200025003000
Service Weightkg70-8070-8070-80
Steering WheelmmΦ180/Φ200Φ180/Φ200Φ180/Φ200
Front Wheel (double)mmΦ74x70/Φ80x70Φ74x70/Φ80x70Φ74x70/Φ80x70
Fork WheelmmΦ80Φ80Φ80
Max. Lifting Heighth1(mm)195/205195/205 195/205
Total Heighth2(mm)116012151215
Lowered Fork Heighth3(mm)75/8575/8575/85
Overall LengthL1(mm)1515/15851530/16001530/1600
Fork Dimensionss/e/l53/160/1220(1150)53/160/1150(1220)53/160/1150(1220)
Distance between Fork Armsb1(mm)550/685550/685550/685
Ground Clearance, Centre of Wheelbasem(mm)323232
Wheel Type PU/NylonPU/NylonPU/Nylon
For more information, please contact us:
Anhui Changjing ElectroMechanical Technology Co., Ltd
Phone: +86 157 1560 6216
Web: www.cjlift.com
Email: send an email
