Cesab ready for Stage 5
- 15 Oct 2020 ( #996 ) - Wellingborough, United Kingdom
Miles Griffin
Miles Griffin
With changes under way to the legislation around IC forklift truck engines, manufacturer Cesab Material Handling is using the challenge as an opportunity for innovation.
New European Stage 5 regulations, aimed at reducing emissions from forklifts, will affect all non-road mobile machinery manufactured from next year.
These rules, which apply to both diesel and LPG forklift trucks, have been described as the world's toughest emission standards, and are designed to improve air quality to protect public health and the environment.
Miles Griffin, general manager of Cesab Material Handling UK, says: "From the end of 2021, all new machine purchases will need to meet Stage 5 legislation, including those between 56 and 130 kw and under 37 kw. They will be required to produce 40% less emissions of particulate matter, or a maximum 0.015 g/kw of soot, regardless of engine size."
Manufacturers will need to show engines are compliant with Stage 5 by putting an emission mark on each engine that can be viewed through the engine access cover. This mark should include the name, manufacturer trademark, engine family name, date of production and a serial number. Engines without this mark will not be compliant.
For LPG trucks, emissions of particulate matter are not an issue, but a catalytic converter is required to eliminate nitrous oxides. The biggest impact is on the diesel forklift market, where the main solution to meeting these requirements has been a diesel particulate filter.
Diesel particulate filters are used to prevent the discharge of soot when an automotive engine is adapted to emit less nitrous oxide. This adaptation includes lowering the combustion temperature using cooled exhaust gas but means that a diesel particulate filter is needed to deal with the resulting soot discharge.
Forklifts with diesel particulate filters usually need to be cleaned regularly, typically once or twice a week. This involves revving the engine for 20 to 30 minutes to burn the soot. The disadvantage of this, for many vehicles, includes high fuel use, increased downtime and lower productivity.
"At Cesab, we've spent several years looking at how our IC range can fulfil Stage 5 regulations without compromising productivity and we've been working towards a solution that addresses the issues around diesel particulate filters," Griffin explains. "Our engineering team has taken a totally new look at the design of the engine, with the aim of producing an option that removes the problems and better meets business demands."
US lawsuit filed against Toyota
US lawsuit filed against Toyota 26 Sep 2024 - San Franciso, CA, United States - 1 min read
California bans propane forklifts
California bans propane forklifts 4 Jul 2024 - Riverside, CA, United States - 1 min read
Toyota admits breaches of engine standards
Toyota admits breaches of engine standards 1 Feb 2024 - Kariya, Japan - 2 min read
Cesab on duty for ESPO News Story - 25 Oct 2018 - Northamptonshire, United Kingdom - 1 min read
XL Joinery choose Cesab electrics News Story - 18 Jan 2018 - Wellingborough, United Kingdom - 1 min read
Cesab launches high-capacity reach truck News Story - 26 Jan 2017 - Brussels, Belgium - 1 min read
