One stop shopping for your vehicle lighting
- 1 Oct 2020 ( #994 )
Are you in need for lighting solutions for industrial vehicles? J.Führ offers true one stop shopping to increase your performance!
At J.Führ GmbH we offer a wide range of high quality products for the lighting of your industrial vehicle. From work lights to driving lights and warning lights. As a supplier of leading vehicle manufacturers, we have a great knowledge of the necessities, so that for almost every application the optimal solution can be found quickly.
Among the most important products are undoubtedly LED worklights and the still relatively new product group of warning zone lights.
Worklights - day bright, even at night!
Even though LED technology is no longer witchcraft and even suppliers of very affordable work lights have found a foothold in the market, it is often worth taking a look at the details. Because it still applies: With modern LED work lights you are able to increase your productivity.
And modern here means that it is not only the pure brightness of a work light that matters. Of course, the materials used also play a role. But what really distinguishes a premium worklight from its cheap counterpart is on the one hand the shape of the emitted beam pattern, and on the other hand, additional functions are becoming increasingly important nowadays.
Worklights on a forklift truck.
There are now worklights that adjust their light cone according to the situation or that have an integrated camera to ensure that the working environment is always clearly visible. But also a changed light color away from pure white can trigger effects. This is especially true for farms that are active in animal breeding.
At J.Führ you can get premium work lights in different sizes and brightness, from compact lights with just 400 effective lumen to real photon cannons with 20.000 effective lumen, from pure white worklights to those with red or green light.
Learn more about work lights here.
Prevent accidents in an easy way!
Warning Zone Lights prevent accidents during operation with industrial trucks and protect employees from injury. You can mark the areas with an increased risk. Even if they are not stationary, but also move with the vehicle! Whether it is a tug truck, a forklift truck or gantry crane.
Warning Zone Lights limit the risks of injury, not the use of industrial vehicles. They are mounted quickly and operate easily with their wide-range input on almost any vehicle. Employees do not need any briefing, because the function is self-explanatory.
At J.Führ you get warning zone lights with different mechanisms of action. But there are three major principles of how warning zone lights work.
  • Periphery Lights - A Periphery light draws a visible colored line on the ground which uniquely marks the boundary of a danger zone. These lights are ideal for the use on forklifts and lifting platforms.
  • Area Lights - With an Area light it's possible to dive an entire zone of increased danger into a distinctly and visibly light. This can effectively mark the entire danger area.
  • Spot Lights - A spot light projects a clearly visible bright spot on the ground, wich points to an approaching danger. This principle is particularly suitable for narrow and unclear corridors and passages.
Combination of a bright spot light with two periphery lights on a forktlift truck.
For the product group of warning lights, it all started back in 2008, when the first warning spot light was introduced with the model 700 (called "BlueSpot"). But today the highlight is certainly the curved line of model 777. These light draws a colored line on the ground which uniquely marks the boundary of a dangerous zone. And model 777 bows for safety!
Semicircular warning line of model 777 on a truck.
Learn more about warning zone lights here.
Contact us for more details:
J.Führ GmbH
Bei der Pulvermühle 7a
22453 Hamburg, Germany
http://www.jfuehr.link/fa
Send an email
