Titan Forklifts: Engineered for Performance, Safety and Comfort
- 14 May 2020 ( #974 )
At Titan, excellence comes standard. Titan commits to building high-quality forklifts that businesses can count on when it matters most. We believe in treating you the way you deserve to be treated and working with you every step of the way.
Introducing the New Titan S-Series
Comes with Suspension.
(Ergonomically improved design that helps with operator comfort and efficiency.)
EXPERTISE
Every Titan Forklift is designed, built and supported by a team of dedicated and knowledgeable professionals, each with their own area of expertise. They all work together to deliver a forklift that is of superior quality both in design and function; Engineers, Product experts, ergonomists, and operators and mechanics all come together for one purpose - to bring our products out.
EFFICIENCY
Titan Forklifts are manufactured using Six Sigma methodologies. Essentially, Six Sigma identifies and removes the causes of defects so as to minimize the "variability in manufacturing and business processes." - Wikipedia: Six sigma
EXCELLENCE
At Titan, a commitment to continuous improvement and innovation is a clear indication of our level of performance and operational excellence. It comes from applying the same patience and diligence to everything we do - from seemingly small tasks to large scale projects and investments, it gives us the shortest path from the factory floor to the customers' satisfaction.
WHY SHOULD YOU BUY TITAN FORKLIFTS?
LOW OWNERSHIP COST
  • Spacious engine bays - Easier to work on which lowers cost to fix and maintain.
  • Fuel Efficient - Some of the most fuel-efficient forklifts.
  • Easy Maintenance - Designed by forklift mechanics with over 40 years' experience to be easy to repair.
WARRANTY
  • 5 years or 6000 hours whichever occurs first. One of the BEST in the industry.
  • Standard on every Titan Forklift.
INNOVATIVE DESIGN
  • Swing Out, Swing Down LPG Tank Bracket - Makes it easier, safer and faster to change propane tanks.
  • LED Working Lights, Strobe Light - Equipped with LED lighting and heavy-duty headlight guards (standard).
  • Overhead Guard Handle with Horn - Conveniently located for easy reach while reversing.
CHOICE OF ENGINES
  • Gas - Nissan, Kubota, Mitsubishi, PSI
  • Gas/LPG Dual Fuel - Nissan, PSI
  • Diesel - Cummins, Kubota, Hatz, Kohler, Mitsubishi
  • Electric - Curtis / AC drive
CHASSIS
  • Solid Cast Body - Durable solid cast body with no pressed in tin parts or plastic, means your forklift stays looking newer longer.
  • Choice of Tires - (Pneumatic air, solids, non-marking solid, dual wheel and cushion).
  • Sizes - from 1.6 Ton to 48 Ton forklifts (3,200 LBS - 96,000 LBS).
STANDARD FEATURES
Three stage 189" Mast, 42"or 48" Forks, Cascade Side Shift, 3rd & 4th Valve, Anti-Start Key Switch, E-Brake safety Switch, LED Light Pkg, Rear Handle with Horn, Strobe light, Eaton Steering (where applicable), Schimadzu Pump, Heavy Duty Load Back Rest, Swing Out and Swing Down LPG Bracket (where applicable), Grammar Suspension Seat, 4 Sets of Keys, Tilt Cylinder Boot Covers.
FOR A DEMO OF A TITAN FORKLIFT
Please contact us at 1-844-93TITAN (844-938-4826)
Titan Forklifts (2016) Ltd
Web:
titanlifttrucks.com
Email: send an email
Phone: 1-844-93TITAN (844-938-4826)
SF: View our ShopFront
