Amerden AGVS: Specialist in retrofitting large AGVs for the Paper Industry
- 28 Jun 2018 ( #878 )
Large AGVs are excellent retrofit projects to be done on site due to the large size and massive steel frame. In most cases the steel frame is the only part that is reused. All wiring and components are removed, the frame is checked for cracks, often sandblasted and painted before new drive/steer units, control panels and wiring are installed.
Read more about Amerden AGVS recent retrofit projects:
Paper Mill - 1
An onsite AGV retrofit project with all new controls and all new wiring of a large, 2 drive/steer, wire guided AGV carrying 50,000 lbs. paper rolls between four stations.
A 2nd safety laser will slow down and stop the vehicle if overhead rolls are detected. The system 24/7 and has automatic battery charging.
Paper Mill - 2
A smaller onsite AGV retrofit project with all new controls and all new wiring of a large, 2 drive/steer, wire guided AGV carrying 25,000 lbs. paper rolls between three stations. The system runs 24/7 and has automatic battery charging.
Amerden AGVS
Roland Anderson
P: +1 (904)-436-6912
E: send an email
W: Amerden.com
Amerden AGVS ShopFront
About Amerden:
Amerden is a full service custom AGV provider - from consulting, design, manufacture, installation and long-term support of your AGV system. Amerden provides cost effective solutions for the most challenging load handling and operational requirements. Every AGV environment is different. At Amerden, each AGV system is uniquely engineered to minimize your operational costs and supply a premium and efficient system tailored for your supply chain needs.
