Series WPH-PH Pipe Hold Down Clamp With Hydraulic Arms
- 12 Apr 2018 ( #867 )
Presenting another new design for pipe and round stock handling from FORK-CO USA's Unit Load Handling Systems brand.
SERIES WPH-PH PIPE HOLD DOWN CLAMP has been designed to allow various diameter rounds to be securely clamped and moved using both powered main arms and powered secondary clamping arms.
This clamp can operate all actions using just one hydraulic function from the forklift.
The WPH-PH series clamp is easily scalable, available in class II, III or IV mountings (FEM 2, 3 or 4) for the smaller forklifts. On larger trucks, the robust PH series is very effective on trucks from 18,000 LB up through 25,000 LB capacity.
WPH-PH series clamp design can be configured to work with the truck's forks from 48 inches long to 96 inches long. It can match most any carriage width.
On special order, the clamp can be plumbed to operate using 2 functions. This gives the operator full control over the clamping arm independent of the main arm movement.
The clamping range is from 2.75" up to 30 inches. Larger diameters on special order.
Padded clamping surface is available on special order for handling coated or exotic materials.
Fork-Co USA (dba) Unit Load Handling Systems
Brian Scally
P: 281-992-2006
E: send an email
W: www.fork-co.com
C: Fork-Co USA online catalogue
SF: ShopFront
MADE IN TEXAS
About Fork-Co USA
Fork-Co USA. builds forklift attachments under its brand name Unit Load Handling Systems.
Fork-Co specializes in providing customized attachments for many industries. Our more than 50 years of application design experience can solve your handling needs.
We celebrate 16 years supplying our products to our customers around the world.
We thank our many customers for their support and confidence in our designs. And we thank them for all the opportunities brought to us.
