ADVERTISEMENT
Camso launches three new press-on tires
Thursday, 23 November 2017 ( #848 )
Left to right: PON 775, PON 555, PON 550
The Material Handling industry has evolved considerably in recent years. Larger forklift models are using more specialized attachments and now come equipped with hydrostatic transmissions, automotive-type active stability systems and specialized attachments. These material movers now have to carry heavier loads in more confined spaces while moving faster. Combined with increased travel distance and less cool-down time between jobs, duty cycles are more severe than ever before.
"When operating in such high intensity applications, tires are pushed beyond their limits and are very likely to experience heat build-up. This can result in rubber fatigue or even thermal tire failure causing unscheduled forklift downtime," says Erick Bellefleur, Product Line Executive Director - Material Handling at Camso. "As the world's largest manufacturer of press-on tires, we know that downtime is not an option for material handling operations. It's our job to understand the unique mobility needs of any forklift and its application requirements," adds Bellefleur.
This is why Camso, formerly Camoplast Solideal, introduces three new press-on (PON) tire models to meet the growing demands of forklifts operating in high- and medium-intensity applications.
THE ALL-NEW SOLIDEAL PON 775 HIGH-INTENSITY TIRE
[image|/upload/gallery/18872.jpg|
Solideal PON 775: designed for high intensity applications
|AlignRight,NoBorder,w250]The new Solideal PON 775 by Camso raises the bar and is especially designed for high intensity applications where other press-ons fail quickly. When compared to the Solideal Magnum SM ERP:
  • It delivers 90% better resistance to internal heat build-up.
  • It shows 70% better energy efficiency due to low-rolling-resistance rubber compounds.
  • It provides 45% longer tire life due to an abrasion-resistant tread compound.
  • It features a unique and patented sidewall design to relieve stress on the tire edges and reduce ground pressure.
A full range of Solideal PON 775 sizes are available, right up to and including a new 33-inch tire.
THE REVAMPED SOLIDEAL PON 555/550 MEDIUM-INTENSITY TIRES
Solideal PON 555: designed for medium intensity applications
Camso's medium-intensity Solideal PON 555 and 550 are enhanced versions of the Magnum traction and smooth models, long established as industry standards. By improving the materials and tire construction process, these new tires will provide:
  • 45% longer tire life
  • 6% better resistance to internal heat build-up
  • 8% improved energy efficiency
"Fleet owners expect maximum life for a tire regardless of the intensity of their job," says Bellefleur. "Our new tire technologies deliver maximum durability by minimizing internal heat build-up."
Together, the new Solideal PON 775 and the Solideal PON 555 and 550 were designed as a series to bring maximum lifespan for different application intensities and to provide customers with the lowest operating cost solution.
For more personalized purchasing advice, consult with your forklift maintenance and tire specialist to discuss your specific usage patterns. Don't forget to discuss the intensity of your application with your forklift OEM, too.
About Camso
We serve the material handling, construction, agriculture and powersport industries by manufacturing and distributing pneumatic, airless and solid tires, tracks, driven and trailed conversion track systems and OEM undercarriages. We even operate our own foundry and go right to the source of rubber. We work from the tree to the tread.
Machinery-onQ Listings
Hyster H23XM12EC
  • HysterH23XM12EC
  • 2015 | Used - Sale
  • Australia
  • AUD 129,000
Hyster H23XM12EC
  • HysterH23XM12EC
  • Australia
  • AUD 135,000
Paus PT36H
  • PausPT36H
  • 2014 | Used - Sale
  • Germany
  • EUR 55,000
Hyster H7.0FT
  • HysterH7.0FT
  • 2013 | Used - Sale
  • Netherlands
Hyster H7.0FT
  • HysterH7.0FT
  • Netherlands
Hyster H22.00XM12EC
  • HysterH22.00XM12EC
  • Australia
  • AUD 115,000
Hyster H12.00XM6
  • HysterH12.00XM6
  • 2012 | Used - Sale
  • Australia
  • AUD 79,000
Yale GLP25RK
  • YaleGLP25RK
  • 2009 | Used - Sale
  • Australia
  • AUD 14,500
Hyster H22.00XM12EC
  • Australia
  • AUD 98,000
Meyer 3-2220N
  • Meyer3-2220N
  • 2008 | Used - Sale
  • Germany
  • EUR 8,900
