With Cascade Specialty Attachments, the Sky’s the Limit
- 10 Aug 2017 ( #833 )
Cascade Specialty Attachment - Large Rotator
No matter what type of material handling challenge you may have, Cascade Corporation can design a solution for you. Cascade's expert engineering team combined with the most cutting-edge tools available enables them to design more custom attachments than anyone in the industry. Whether handling heavy-duty loads like 50,000 kg (110,000 lbs) of slab steel, oversized tires for large vehicles or massive concrete piping, Cascade can provide an innovative and effective solution for the most demanding applications.
Well-known for leading the market in worldwide customer support and engineering excellence, Cascade is preferred by customers around the globe for versatility, durability and reliability when it comes to specialty attachments. According to Cascade Canada's Joe Botelho, Special Application Product Sales Manager, "From Australia to China to the US and Europe, our special application product team is committed to providing that perfect solution to meet our customer's explicit requirements. In collaboration with our global engineering group and worldwide sales force, we partner closely with the customer to ensure that only the highest quality product is delivered to their door."
Incomparable Solutions for Large-Scale Applications
Cascade produces a wide variety of attachments for the biggest jobs and toughest applications. From the port and harbor industry to the concrete and metal industries, Cascade provides unparalleled solutions for handling the heaviest loads for the largest lift trucks in operation today.
Heavy Lifting with Concrete Handler
When a major US concrete pipe manufacturer needed to do some heavy lifting for a water main construction project in California, they called on Cascade to provide a solution that would uniquely fit their needs. Handling concrete pipes weighing up to 7,500 kg (16,500 lbs) and ranging from 400 mm (16") to 2,235 mm (88") in diameter, Cascade worked closely with the customer to design a big rotating concrete pipe clamp that could easily lift, carry and rotate the pipes for transport.
In order to securely handle this load and eliminate any damage to the concrete pipe walls, special rubber faced pads were created for optimal clamp force distribution. This specialty unit also incorporates four drive groups, long and short arms with eight clamping cylinders, as well as special hydraulic valves to ensure both a secure grip and sufficient torque to rotate the oversized concrete structures.
Heavy Lifting with Cascade's Specialty Rotating Concrete Handler
Large-Scale Handling with Cascade's Speciality Pulp Bale Clamp
Large Handling with High-Volume Pulp Bale Clamp
Another Cascade customer is also able to navigate their way to more efficient handling by successfully implementing a Cascade specialty product in a large-scale application. A full-service European port requested a pulp bale clamp from Cascade that could move their high-volume loads - 64 bales of pulp at once. Handling up to 18,000 kg (39,600 lbs), this is the largest pulp bale clamp Cascade has built to date.
To handle such a substantial number of pulp bales per load, a middle arm was specially designed to ensure precise and secure handling. This clamp's durable design also features equal arm pressure for reduced product damage and a thin arm profile for knifing between tightly stacked bales. These special features now allow the port to quickly and securely transport high-volume cargo from the warehouse to the dock while minimizing downtime and improving productivity.
To learn more about Cascade's specialty products and how we can find a custom solution to fit your needs, please visit www.cascorp.com, send an email or contact your
local Cascade representative.
Cascade Corporation
Portland, Oregon
1-800-CASCADE (227-2233)
www.cascorp.com
For more company and product information visit the Cascade ShopFront
About Cascade Corporation:
Cascade Corporation was established in Portland, Ore. in 1943 and is the global leader in the design, manufacturing and marketing of material handling and construction equipment and related technologies. Cascade's unmatched service, support and expertise, combined with their advanced damage reduction technologies, flexible manufacturing, short lead times and quality products, strengthen the company's position as the premier supplier to the material handling industry. For more information visit www.cascorp.com.
1 800-... Show
Corporate Office
2201 NE 201st Ave,
Fairview, OR 97024
U.S.A
