Snorkel shows new line in the UK
- 25 May 2017 ( #822 ) - Washington, United Kingdom
Snorkel's ML16M
Snorkel's ML16M
Aerial work platform manufacturer Snorkel has unveiled its new material lift line to the UK market at Vertikal Days at Silverstone.
Split into two product families, the Snorkel material lift range includes three MLC models designed for heavy-duty, construction applications, as well as three MLM models featuring a shorter mast height and compact design.
The display at the show includes an ML18C material lift capable of a 5.1m lift height with up to 318 kg of load capacity at a 0.36m load centre. The Snorkel ML18C material lift weighs 141 kg and has compact stowed dimensions of 0.77 m x 0.85 m.
Also on show is the popular Snorkel SL26SL Speed Level. The Snorkel Speed Level features a recently enhanced stowed drive speed of 6.4 km/h. It can be driven at full working height, even on slopes, which increases efficiency by eliminating the need to elevate and lower the lift between tasks.
Two electric slab scissor models, the S3215E and the S4732E, can also be seen at the display.
Snorkel UK is also showcasing a number of Snorkel's most popular lifts at the show, including the Snorkel TM12 telescopic mast lift with roll-out extension deck, the Snorkel A38E electric articulated boom lift, the Snorkel A46JRT rough-terrain articulated boom lift, the S3010P push around scissor lift and the S3010E hydraulic drive scissor lift.
Vertikal Days, which moved to Silverstone this year, is a major European showcase for lifting and access equipment.
Wrap-around lift demonstrated
Wrap-around lift demonstrated 8 Dec 2016 - Manchester by the Sea, MA, United States - 1 min read
LiftPod gaining acceptance, JLG drops earlier version 10 Jun 2010 - McConnellsburg, PA, United States - 1 min read
Palfinger buys into Equipment Technology
Palfinger buys into Equipment Technology 1 Apr 2010 - Oklahoma City, OK, United States - 1 min read
Snorkel debuts Li-ion boom News Story - 30 Sep 2021 - Henderson, NV, United States - 1 min read
Manufacturers offer finance, support News Story - 25 Jun 2020 - 2 min read
Snorkel joins Cat Allied Vendor Program News Story - 7 May 2020 - Henderson, NV, United States - 1 min read
