Protect your people near moving vehicles
- 9 Feb 2017 ( #807 )
Pedestrians and vehicles don't mix. The BODYGUARD i-TAG ensures your team go home to their loved ones. If you want to make sure no one gets hurt and staff go home at the end of each day, the BodyGuard i-Tag is the perfect solution to improve safety around vehicles in the workplace.
It's a pedestrian proximity warning system that can stop your vehicle operators and pedestrian staff from colliding into each other.
The system is made of three components which interact with each other:
  • A personal tag - worn by pedestrians
  • A sensor unit - attached to the vehicle
  • A cab alert unit - which speaks to the driver
When a pedestrian, wearing a personal tag, gets too close to a vehicle, it is picked up by the vehicle's sensor unit and informs the driver via the cab alert unit (even through solid objects).
The cab alert unit warns the driver by unmistakable, high impact siren and human voice ("look out! person near you") so you can be sure the driver will hear it and hit the brakes to avoid an accident. This is unlike other beeping systems with alerts that get lost in the din of an industrial site.
Both the cab alert unit and sensor unit components are magnetically attached so there's no need to spend money on complex installation or modifications to the vehicles. They're easy to install and simple to remove making them especially ideal for leased or rented vehicles.
In summary, the BodyGuard i-Tag is:
  • Made of three components
  • Easy to install, easy to remove
  • Simple to use
  • Has a loud alert system with human voice
  • Will help your people avoid fatal collisions
Reduce the risk of having an accident on your site.
With the BodyGuard i-Tag proximity warning system, you can avoid collisions from happening on your site. The system will protect your people from harm, promote a culture of safety and reduce downtime costs.
BodyGuard Safety Solutions
'Your Risk is our Business'
P: +61 (2) 43 554 554
E: send an email
W: www.bodyguardsafety.com.au
SF: ShopFront
