Want to do something really nice for your forklift operators this Summer?
- 5 May 2016 ( #768 )
KEYTROLLER has a COOL new Summer Promotion---something that will make every forklift operator---very, very happy!
For every LCD-601/2 wireless access monitoring device purchased this Summer Keytroller will provide one FREE new COOLTROLLER--SEAT or COOLTROLLER--DUAL FAN operator cooling system. With the purchase of a KEYTROLLER LCD you can insure no unauthorized or untrained drivers can start your equipment, you can automate your OSHA required daily checklist, you can schedule both maintenance and training, you can evaluate loaded vs unloaded or moving vs idle and you can make abusive operators accountable for damage and speeding.
Purchase by Sept 1 and you get a FREE COOLTROLLER----your operator will thank you and a cool operator is a more productive operator!
COOLTROLLER--SEAT
This 16" X 16" (41cm X 41cm) cushion has 2 fan air intakes. These fans push a cooling breeze through the cushion and up between the bamboo platelets and up to the operator's bottom or back.
INSTALLATION:
Not much too it----just connect to 12---48VDC input power and set the cushion on the seat for the operator to sit on or lean it on the seat back for the operators back to lean against. Either way, the moving air will be a welcome relief to a forklift operator who often is sitting over top of a hot engine compartment.
Each COOLTROLLER--SEAT includes:
  1. 16" x 16" seat with 2 input fans and bamboo platelets for dispersing air out
  2. 5' cable
  3. On/off switch in line in cable----should be connected to switched power.
  4. Be sure to order proper model for 12VDC or 24-48VDC input power!
Features:
  • EASY TO INSTALL - Just place on seat and sit on it or place on back of seat and lean on it
  • 2 wires to power (12 VDC), Voltage converter included in 24-36-48 VDC model
  • Sized to fit to any seat
  • Moving air continuously cools drivers bottom or back - operators love it!
  • Heavy duty bamboo platelets insure long life and cool air outlets to sit on
  • Low current draw of 3W - minimum load on vehicle electrical system
Purchase Price: $70 (12V model) $80 (24-48V model) Dealer discounts available
COOLTROLLER-DUAL FANS
COOLTROLLER Dual Fans by Keytroller
A cool operator is a productive operator! Economical and easy way to cool down your drivers!!
Dual fans generate cooling breeze pointing down at your equipment operator. Motors are 100% copper wound for longevity.
Powered by 12VDC or 24-48VDC input power --typically connected to vehicle switched ignition power. There also an on/off Hi/Lo switch on the fan module.
Full 360 degree all around adjustment of both motors on the module---Up/Down and Right/Left allows operator to easily direct cooling breeze where he wants it!
INSTALLATION:
Not much too it----just connect to 12---48VDC input power. Double sided tape makes it easy to mount the dual fan module on the overhead guard or rack of most vehicles. Many clients further secure the assembly with plastic cable ties.
Each COOLTROLLER-DUAL FANS Kit includes:
  1. Dual adjustable position fans
  2. 5' cable (12VDC input only) Voltage converter required for 24-48VDC vehicles
  3. On/off switch on device with Hi/Lo settings - should be connected to switched power
Features:
  • EASY TO INSTALL - mounts to overhead guard, in front, behind or beside the operator
  • 12 VDC Model and 24-48 VDC model Be sure to order by input voltage!
  • Each fan head is independently adjustable
  • 360 degree both horizontal and vertical
  • 100% pure copper motors
  • Ultra quiet - low noise design <45dB
  • On/Off - Two speed switch on device
  • 8"H X 3.5" D X 5.5" H----small enough to fit to most any vehicle
Keytroller hopes you'll make your forklift operators a little "cooler" this Summer!
For more information view website: www.keytroller.com or contact KEYTROLLER, LLC. 813-877-4500 or email: send a message, Click here to visit the KEYTROLLER ShopFront
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
