KOOI-REACHFORKS®: 'Save time, space and money'
- 10 Dec 2015 ( #748 )
IMPROVE EFFICIENCY AND SAFETY
In difficult times, the simple solutions are often overlooked. MSE-Forks offer some of the most ingenious and cost effective solutions for helping companies reduce their operational costs.
Something as simple as changing the forks on your lift trucks from standard forks to hydraulic telescopic KOOI-REACHFORKS® can help you speed up (un)loading time, cut internal transport costs in half, improve space utilization and reduce damages to both goods and pallets.
35 YEARS OF EXPERIENCE
MSE-FORKS B.V. is based in the North of The Netherlands. We are the original inventor of the hydraulic extendable forks, and with more than 35 years of experiences and thousands of satisfied customers, the KOOI-FORKS have become "the standard" for most forklift manufacturers. We can offer you the highest quality products available.
25% TIME SAVING BY ONE SIDED LOADING/UNLOADING
Many companies still load and unload trucks from both sides. The lift truck driver has to drive around the truck repeatedly. By using telescopic forks it is possible to load and unload pallets from one side. This not only saves 25% in time, it is also much safer because the lift truck is always at one side of the truck. Because of the extra space trucks can sometimes even be (un)loaded indoors.
50% REDUCE OF COSTS WITH DUAL LOAD TRANSPORT
Many companies have lift truck operators transporting single pallets back and forth all day long. The simple addition of telescopic forks can allow two pallets to be carried at one time instead of just one. Not only does this reduce internal handling by 50% it also lowers fuel consumption and maintenance costs since the forklift is only making half the trips as before.
30% EXTRA STORAGE WITH DOUBLE-DEEP STACKING
Stacking pallets double deep with hydraulic lift truck forks has become an easy way to increase storage density and maximize space utilization. By stacking pallets double deep, four pallets can be stored between each aisle which offers ± 30% extra storage volume. This can help companies avoid offsite storage or building expansion costs as it allows them to utilize the full potential of their facility.
50% LESS DAMAGES TO PALLETS AND GOODS
A lot of companies are unaware of the fact that lift truck forks that are too long often damage the goods and pallets. Research points out that this is an important issue, but, despite the detection, it seems an underestimated problem and those damages are treated as hidden costs. The lift truck driver is always in a hurry and therefore he will always drive the forks completely in a pallet without thinking about the size of the pallet. When using smaller pallets, forks will stick out at the back of the pallets and will damage the goods that are behind it, with the result of all kind of extra costs.
With hydraulic extendable forks these damages are prevented.
More info at www.telescopicforks.com
MSE Forks
St. Jacobiparochie, Netherlands
Telephone: +31 518 492929
email: send us a message
Website: www.mse-forks.com
MSE-Forks is based in the Netherlands, with a wholly owned subsidiary in the USA and distributors in more than 60 countries worldwide. The company is the world market leader, being the largest producer of hydraulic lift-truck forks, more commonly known as "KOOI-REACHFORKS®". However, MSE-Forks also produces a wide range of other innovative material-handling solutions, including: Mast Height Extensions and manual KOOI-REACHFORKS®, as well as a complete range of pallet-less handling solutions such as ROLLERFORKS®, Push-Pulls, Stationary Pallet Changers. Also, MSE-FORKS sells the patented FLEX-OPS®, a safety enhancement for fork-lift trucks that helps prevent tip-over accidents.
