Is your forward-reaching log or pipe handling truck costing you?
- 10 Dec 2015 ( #748 )
The Cary-Lift 154 is optimized for construction as well as oil and gas applications.
With swings in the marketplace becoming the new normal, controlling your costs is no longer just a good idea, it's a practical necessity. The Pettibone Cary-Lift 154, the most effective forward-reaching rugged terrain lift truck in its class, puts cost efficiency, productivity, and safety at the forefront of the most advanced design in the industry.
Whether your application is in forestry, construction, or oil and gas, your bottom line needs the Cary-Lift 154.
More Versatile and Efficient: Do More with Less
The Pettibone Cary-Lift 154 delivers the traditional load handling power and dexterity of other models in the Cary-Lift series but adds a variety of new features to meet the ever-changing needs of users. With a streamlined design, simplified maintenance, and enhanced operator comfort, the Cary-Lift 154 lets you do more with less while remaining one of the most versatile material handling solutions in the industry.
An indispensable tool for the forestry industry.
Stronger and More Maneuverable: Take Loads Anywhere
The Cary-Lift 154's solid steel frame far surpasses other in-class forward reaching-trucks in stability and load capacity.
And, as it's driven by a 160-horsepower Cummins QSB 6.7L Tier III diesel engine, the Cary-Lift 154 can provide maximum capacity of up to 15,000 pounds or 10,000 pounds when extended to a full 14 feet of lift height. The extra power and heavy frame don't mean less maneuverability, however, and with a narrow 10-foot wheelbase and the ability to switch between three steering modes, no other truck can match the 154's 16-foot turning radius without sacrificing load capacity or stability.
Better Lines of Sight and Extra Stability: Be Safer AND More Productive
Enhanced operator range of vision now comes standard.
Further improving safety is the Cary-Lift 154's unique overhead lift arm design, a signature feature of the Cary-Lift series, which allows the operator to maintain full forward visibility when transporting or placing loads. The 154's large safety glass windows are tinted against glare while the sloped engine compartment also improves rear line of sight for better, safer driving. Safety is also emphasized through extra-wide lift arms for load stability and hydraulic frame sway control that comes standard on the Cary-Lift series.
Better Controls and Better Ergonomics: Improve Your Workflow
The Cary-Lift 154's improved controls mean greater speed and safety.
And with an improved electrohydraulic system that offers infinite variable control, the operator can safely steer the truck with one hand while using the intuitive multifunction joystick with the other. This permits a smooth, uninterrupted workflow for maximum control, safety, and productivity.
The Cary-Lift 154's cab has been redesigned from past models, with an easy-access sliding door, tilt steering, and an adjustable suspension seat that features a seat belt, padded armrests, and lumbar support. Full climate control allows for maximum comfort in any weather conditions while operator controls can be fully customized to best fit your operator's work style. There's even a stereo and a CD player.
Routine maintenance and refueling is easier and faster.
Easier Maintenance and Faster Refueling: Spend More Time in Your Truck Than Out of It
Routine maintenance is now simple thanks to a centralized lubrication system. One easy-to-reach access point takes care of most of your lubricating needs. The Cary-Lift 154 also features balanced dual fuel tanks with a single ground-level refueling port, putting you back on the job sooner.
H&K Equipment Is Your Pettibone Cary-Lift Dealer
For additional information, spec sheets, rental options, or to schedule a demo, contact H&K Equipment. We are your leading full-service supplier of high-capacity material handling equipment and have the right sales and rental solutions for your business.
H&K Equipment is your full-service dealer for the Pettibone material handling equipment.
Contact:
Richard Rich
Wholesale Manager
4200 Casteel Drive
Coraopolis, PA 15108 USA
1 (412) 490-5300
send an email
www.hkequipment.com
H&K Equipment ShopFront
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
