New S150 from Sellick
- 12 Nov 2015 ( #744 ) - Harrow, ON, Canada
The new S150
The new S150
Sellick Equipment has added a new model to its rough-terrain forklift range.
The new S150 can lift 15,000 lb. (6,800 kg) at a 24 in.(60 cm) load centre, and is powered by an economical 74hp, four-cylinder intercooled Tier 4 Final electronic engine.
The S150 features a fully isolated operator platform that reduces noise and vibration, and the overhead guard structure is both ROPS- and FOPS-certified.
Operators can monitor the machine's systems through a multi-function digital LCD screen that also provides on-board diagnostics that reduce downtime.
The new model is equipped with Sellick's SEE-THRU high-visibility two-stage or three-stage mast assemblies. Side shift is standard and a wide range of carriage types, fork lengths and attachments are available.
The S150 is designed for heavy industrial applications such as steel and plastic pipe manufacturing/distribution, steel fabrication, engineered wood products, concrete products, automotive recycling and public utilities.
The S150 is now in full production.
Linde launches new pallet truck and double stackers
Linde launches new pallet truck and double stackers 24 Oct 2024 - Aschaffenburg, Germany - 1 min read
Raymond boosts 4750 range
Raymond boosts 4750 range 1 Sep 2022 - Greene, NY, United States - 1 min read
New leadership at Sellick News Story - 17 Feb 2022 - Harrow, ON, Canada - 1 min read
Sellick opens new manufacturing facility News Story - 22 Feb 2018 - Harrow, ON, Canada - 1 min read
Work starts on new Sellick facility News Story - 12 May 2016 - Harrow, ON, Canada - 1 min read
