SPI, a new revolutionary stand-alone system made by MSE-Forks®
- 8 Oct 2015 ( #739 )
The stand-alone Stationary "Push/Pull", SPI, provides a highly efficient and cost effective means of transferring unit loads from one load carrier to another. It's especially useful for keeping wooden pallets outside of cleanroom areas in order to comply with hygiene regulations.
This compact unit provides the beneficial features of a hydraulic push/pull attachment, (for slip-sheet handling), without the added expense of a dedicated forklift truck and an additional operator. This saves money. Loads are easily pulled from one pallet onto another. Delicate loads are safely transferred without the risks often associated with clamping or pushing. This reduces product damage and repackaging costs. It's also easy to use and does not require the skill levels necessary of forklift operators working with specialized attachments.
See the Stationary Pull Installation in action!
A small footprint, simple plug-n-play type design and an innovative laser-light safety curtain makes this unit ideal for placement within receiving areas. It offers an easy means of isolating unwanted pallets from other areas of the facility.
Cost saving benefits:
  • Reduce contamination risks
  • Avoid unnecessary costs, (eliminate the need for an additional forklift)
  • Reduce product damage, (no pushing forces and no clamping forces on goods)
  • Improve throughput rates, (stationary placement for standardized process)
  • Lower operational costs, (low maintenance and low energy consumption)
Innovative features:
  • Simple construction
  • Heavy-duty design
  • Easy operation
  • No inversion of loads
  • Minimal floor space requirement
  • Remote controlled operation
  • L-shape Safety light curtain
  • Independent hydraulic system
  • Plug & play design
Standard Options :
  • Warning buzzer
  • Warning beacon light, (LED)
  • Oil level and temperature warning
  • Full surround safety light curtain
  • Galvanized or stainless steel construction parts
  • Other voltages, amperes, etc. on request.
MSE Forks
St. Jacobiparochie, Netherlands
Telephone: +31 518 492929
email: send us a message
Website: www.mse-forks.com
MSE-Forks is based in the Netherlands, with a wholly owned subsidiary in the USA and distributors in more than 60 countries worldwide. The company is the world market leader, being the largest producer of hydraulic lift-truck forks, more commonly known as "KOOI-REACHFORKS®". However, MSE-Forks also produces a wide range of other innovative material-handling solutions, including: Mast Height Extensions and manual KOOI-REACHFORKS®, as well as a complete range of pallet-less handling solutions such as ROLLERFORKS®, Push-Pulls, Stationary Pallet Changers. Also, MSE-FORKS sells the patented FLEX-OPS®, a safety enhancement for fork-lift trucks that helps prevent tip-over accidents.
