Introducing the Key-Roller self balancing, electric powered, personal transporter
- 27 Aug 2015 ( #733 )
Key-Roller is especially useful in large industrial or warehouse facilities where managers frequently walk long distances.
The Key-Roller is a self balancing, electric powered, personal transporter that will get a manager from one place to the other at up to 9 miles per hour.
Click here to view the marketing video
Key-Roller is especially useful in large industrial or warehouse facilities where managers frequently walk long distances. The transporter is very easy to drive when trained properly and with a little practice a manager will quickly see the utility and effectiveness of the product. When getting from one place to the other takes much of your time and energy Key-Roller is a welcome advantage. It's incredibly tight 0 degree turning radius and positive control allows maneuvering in event the most confined areas. The transporter is effectively used in manufacturing plants, warehouses and even offices.
Unlike a bicycle or unicycle, the KEY-ROLLER has an internal gyroscope which balances the operator automatically. You can see this very easily by trying to get on the unit with power off. The unpowered unit is nearly impossible to balance on. With power on, the gyroscope automatically makes hundreds of tiny adjustments every minute. It is very easy for even a novice driver to step on and balance himself. Just like a bicycle the driver can fall off and get injured if he is untrained or careless. Like a bicycle the likelihood of a fall off or collision accident drops with more drive time, confidence and experience. Check with your safety department about the company requirements for safety helmets or knee or elbow pads before using this device.
Click here for the PDF operation manual Click here for the operator training video
To insure that only trained and authorized operators can operate the transporter, the kit comes with two wireless FOBs required to enable the unit. There are 5 LEDs on the transporters which represent the state of charge from 20-100%, when the charge level reaches one LED (20%) the battery should be recharged. The Key-Roller comes with a plug in wall charger and it's lithium ion battery can charge from flat to full charge in 4 hours and has a travel range from 5-9 miles (10-15KM) depending upon operator weight, grades and amount of low speed maneuvering. The transporter is easily transportable at only 45 pounds (20KG).
Industrial users of the KEY-ROLLER do not buy it for entertainment purposes. When used properly it is a very effective tool for managers who walk long distances. It will reduce wear and tear on the body and get the manager where he needs to go safely, efficiently and much faster. This leaves a manager more time for productive work while giving him more energy to do his duties.
Click here to download the PDF literature and specification sheet
Key-Roller is shipped via Fedex or UPS and easily assembled in only a few minutes. Demos are available to qualified clients.
Call your Keytroller rep at: 813-877-4500
For more information about KEYTROLLER view the website: www.keytroller.com, visit the ShopFront, or contact KEYTROLLER, LLC. 813-877-4500 or send an email
