Meet Cascade at the Show - Logistik and Transport 2015
- 7 May 2015 ( #717 )
Cascade, the global leader in providing material handling solutions, including sophisticated forklift attachments and custom forks, will exhibit at Logistik 2015 in Gothenburg, Sweden May 19-21. Click here to register for your complimentary tickets.
Find Cascade at Booth C02:12 featuring a variety of products including their intelligent White Goods Clamp. The WG series with VFC (Volumetric Force Control) is an innovative combination of electronic systems and hydraulic mechanisms paired with unrivaled Cascade design and structure. The Volumetric Force Control (VFC) automatically adjusts clamping pressure based on the volume of the load. This product is designed to reduce damage caused by excessive force applied to the load when manually controlling the pressure. The VFC calculates the size of load and will clamp with the right amount of force. Force distribution is also ensured by the patented three-finger arm design, the six adjustment points on each arm, the Cascade proprietary Adjusta-Block system and the extended height arm. The White Goods Clamp with VFC is designed to maximize efficiency and speed as well as to protect the load of packed products (including the profiled arm corner casting to eliminate corner pinching damage).
Stop by the booth to learn more about Multiple Load Handlers. Cascade Single-Doubles allow drivers to use the same lift truck to handle either single or double pallet loads. Spread the four forks to handle two pallets side-by-side. Forks are hydraulically positioned for fast and efficient handling.
Cascade sideshifting and non-sideshifting Fork Positioners save time and avoid product damage by allowing drivers to position the forks directly from the truck cab. Ask about the innovative Fork Positioner Conversion Kit that transforms Sideshifters into Fork Positioners with just nine bolts.
Paper Roll Clamps can be equipped with different types of pads for damage-free handling of any type of paper. Cascade manufactures both large and small capacity Paper Roll Clamps specially designed for use in ports, mills, warehouses, publishers and anywhere you need to deliver a perfect roll every time.
Visit Booth n. C02:12 to discuss products for your specific application. Cascade's highly skilled sales people can recommend a customizable material handling solution based on your individual needs, including rental and remanufactured alternatives.
If you cannot attend the show, visit www.cascorp.com for more information about Cascade, the new PERFORMANCE two-year warranty, or for more information about any of Cascade products and services.
Cascade Corporation, established in Portland (OR) in 1943 and with subsidiaries in Germany and around the world, is the global leader in the design, manufacture and marketing of materials handling attachments, forks, accessories and related technologies. Their unmatched service, support and expertise, along with advanced damage reduction technology, flexible manufacturing, short lead times and quality products, positions them at the forefront of the material handling industry.
Cascade Corporation
Portland, Oregon
1-800-CASCADE (227-2233)
Send Cascade an email
www.cascorp.com
For more company and product information visit the Cascade ShopFront
