The ultimate test for transferring octabins
- 2 Apr 2015 ( #712 )
Pallet Changer transferring Octabins
Our latest video demonstrates how quickly and easily an octabin filled with liquid can be transferred from one pallet to another using the Stationary Pallet Changer, (SPC). This test was conducted in order to show meat and poultry processors how their octabins or combo bins can be transferred from wood to plastic without any problems. Even under the most extreme circumstance, 'when an octabin is filled with liquid', the Stationary Pallet Changer succeeds!
Transferring an octabin filled with liquid from a plastic to wooden pallet
In this case, the Smurfit-Kappa liquid packaging "One-Trip Liquid Packer" combo filled with 940 l/248 gal. of water was transferred from a plastic to a wooden pallet within a complete cycle time of just 14 seconds, (movement of faceplate out/in). Of course the Stationary Pallet Changer can also be used to transfer other types of unit loads as well. Using the Stationary Pallet Changer offers the following cost saving advantages:
  • Stand-alone stationary design with compact footprint (takes little floor space)
  • No additional operators, (personnel), required
  • No need for a dedicated lift truck
  • No extra attachment or hydraulics required on lift trucks
  • Low cost electric operation
  • Very low maintenance
  • Less expensive than mobile equipment systems
The Stationary Pallet Changer, (SPC) is a remote-controlled efficient and compact stand-alone unit which provides excellent performance. It's ideal for applications where goods need to be transferred from wooden to plastic pallets or vice-versa. This pallet transfer innovation has become increasingly popular due it's robust and simplistic design and cost-effective character.
The Stationary Pallet Changer can also be used in combination with forklift trucks fitted with ROLLERFORKS® or Push-Pull attachments allowing goods to be transferred off pallets and loaded directly onto the floor of a trailer or container for pallet-less shipment.
Food and Pharmaceutical companies are finding the Stationary Pallet Changer an invaluable asset to their operations as it provides a simple, efficient and cost effective means of load transfer. The SPC makes it easy to transfer unit loads and isolate certain load carriers from clean-room environments.
MSE Forks
St. Jacobiparochie, Netherlands
Telephone: +31 518 492929
email: send us a message
Website: www.mse-forks.com
For more company and product information visit the MSE Forks ShopFront
MSE-Forks is based in The Netherlands, with a wholly owned subsidiary in the USA and distributors in more than 60 countries worldwide. The company leads the world market as the largest producer of hydraulic lift truck forks, more commonly known as "KOOI-REACHFORKS®". However, MSE-Forks also produces a wide range of other innovative material handling solutions including: Mast Height Extensions and manual KOOI-REACHFORKS® as well as a complete range of pallet-less handling solutions such as ROLLERFORKS®, Push-Pulls, Stationary Pallet Changers and more, www.slip-sheet-attachments.com.
