Lencrow introduces the new world class 4 wheel EP electric range
- 7 Aug 2014 ( #679 )
The new world class 4 wheel EP electric range. Click for larger view
Lencrow is proud to introduce the new range of 4 wheel electric forklifts. These units are built with world class components, which produce a state of the art 4 wheel counterbalance electric forklift.
The forklift has dual front drive motors and ZF transmissions that are manufactured in Germany. The advantage of the dual front drive system is the improved maneuverability and has superior stability. The unit also has improved traction on uneven and wet surfaces. The traction motors are AC operation offering better duty cycle times and this is controlled by Zapi controllers from Italy.
The units wiring is connected with AMP water proof connectors from the USA and line contactors are Albright's from the UK.
The unit's hydraulic system uses a Shimadzu pump from Japan and the steering actuator is Eaton from the USA. This combination offers fast operation times with smooth precise steering.
Ross Grassick managing Director of Lencrow says "I visited the EP Factory in China this month and had the chance to drive and see the production of the new CPD18FVD units. The unit is one of the most responsive units 4 wheel units I have driven and I purchased our first unit on the spot. I feel with the move to electric units in Australia that this unit offers performance that will suit more applications than units offered by other manufactures. The units are priced very well with the quality this unit affords."
The unit also offers improved driver features that include larger driver's compartment and low profile access.
These units are now available in Australia with the 1800kg unit in stock and the new 2500kg unit available in October. The full range covers 1500-3500kg units with lift heights up to 6500mm.
For more information contact Lencrow Materials Handling on 1300-536-276 or at www.lencrowgroup.com.au
e: send an email
w: www.lencrow.com.au
t:
1300 536 276
Click to view the Lencrow Materials Handling ShopFront
