New Manual Extension Forks: Innovative design for high user friendliness!
- 8 May 2014 ( #666 )
A simple fingertip locking mechanism, allows the forks to be extended manually and locked into an extended position - Click images for larger view
If you have an occasional need for handling variable load lengths, manual extension forks provide an ideal solution. They don't require hydraulics and they offer a lower investment cost than hydraulic extendable forks, this makes it a nice option for companies with budget constraints. To extend the lift truck tines, the lift truck driver simply gets off the truck and moves the extending portion of the forks by hand.
Innovative locking system
What makes the manual extension forks of MSE-FORKS unique is that they have a highly innovative locking system. With this patented system the use of manual extension forks is no longer characterised as time-consuming, wear-sensitive and injury prone. The operator simply releases a fingertip locking lever at the end of the fork and slides them into position where they lock into place. The forks are always available when needed and no heavy lifting is required. They help keep your employees productive and safe. The unique extendable sleeves offer some important USP's:
  • Closed locking slots protect the locking pin.
  • No loose parts needed to lock the sleeves.
  • Extension in just one simple movement by moving a pin.
  • Eliminate safety risks and inconveniences typically associated with loose fork extensions (outer sleeves).
Click to enlarge
Click to enlarge
Manual Extension Forks provide a simple solution for applications which have infrequent need for handling differing load sizes. For more demanding applications, we recommend our original hydraulic telescopic KOOI-REACHFORKS® which allow length adjustment at the touch of a lever.
More information: www.telescopicforks.com.
MSE-Forks is based in The Netherlands, with a wholly owned subsidiary in the USA and distributors in more than 60 countries worldwide. The company leads the world market as the largest producer of hydraulic lift truck forks, more commonly known as "KOOI-REACHFORKS®"; however, MSE-Forks also produces a wide range of innovative materials handling solutions including: Height Shift Systems, (vertical lift forks), telescopic Jib Crane attachments and booms as well as a complete range of palletless handling solutions such as ROLLERFORKS®, Push-Pulls, Stationary Pallet Changers and other products (www.slip-sheet-attachments.com). The latest MSE-Forks product to be introduced to the market is the patented FLEX-OPS, a safety enhancement for forklift trucks that helps prevent tip over accidents, www.mse-ops.com.
MSE Forks
St. Jacobiparochie, Netherlands
Telephone: +31 518 492929
email: send us a message
Website: www.mse-forks.com
For more company and product information visit the MSE Forks ShopFront
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
