RUYI Counterbalance Electric Stacker
- 8 Aug 2013 ( #628 )
CPD15R (Rider) Click image to enlarge
RUYI's Counterbalance Electric Stacker CPD15W and CPD15R feature wide front views, low gravity, small turning radius, good performance and easy operation. It is the ideal option for materials handling and goods stackers in Narrow-Aisle warehouse.
Advantages:
STRUCTURAL:
  • The truck has compact structure and low gravity which ensures good steering stability.
  • Two lifting cylinders placed on the outer sides of the mast improve the lateral stability and widen the operator's view.
  • Imported German special steel mast.
  • Vertical driving wheel, with high driving efficiency and low noise, easy installation and maintenance.
CPD15W (Walkie)
CPD15W (Walkie)
SAFETY AND EFFICIENCY:
  • AC frequency conversion traction motor: compact structure, good performance, regenerative braking and easy maintenance.
  • Forks with tilting system for easy loading and stacking.
  • Turning radius of 1,560mm is ideal for narrow spaces.
  • High storage battery ensures strong and long-lasting power.
  • Meter with BDI w/interrupt, prolonging the battery's run time.
  • The braking system combines magnetic brakes and regenerative brakes, greatly prolonging the lift use of friction the plate.
  • The emergency stop switch, electric lock button and multi-valve controlling levers provide for ergonomic operation.
  • The adjustable regulator valve can adjust the lowing speed of the masts.
EASY MAINTENANCE:
  • Uses magnetic suction (no screws) for battery cover closing, for easy installation and maintenance.
  • AC control system with sensitive reaction, low noise and less maintenance and accurate speed control.
For further information regarding any model in RUYI's range, please
contact:
Mr. Chu Jiang
Vice President
NINGBO RUYI JOINT STOCK CO., LTD.
Tel: +86-571-87153626, 87153634
Fax: + 86-571-87153628, 87153638
E-mail: sales@xilin.com/ ruyi@xilin.com
Website : www.xilin.com
Click here to view Ruyi's Shopfront
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
