Ruyi Launches Its New Reach Lift Truck
- 15 Nov 2012 ( #591 )
Click image to enlarge
In 2012, Ningbo Ruyi Joint Stock Co. Ltd. Continues to innovate with its new 2 ton Reach Truck with a 12 m maximum lift height - fully tested to qualify for
CE certification.
Max Lift Height 12M
CQD20H has a very small turning radius of 1,820mm, making it ideal for large warehouses and supermarkets, etc. It is among the most energy-efficient vehicles in the field. Its features include:
STABILITY
  • The large and strong chassis ensures sufficient stability of the forklift.
  • The max lifting height can reach 12 meters.
  • Use "H" type mast steel is imported from Germany, ensuring longer use time and stability.
  • A large and comfortable compartment with adjustable seat reflects a concept of ergonomic design.
  • Use of double controllers to realize stepless speed regulation of both lifting and travelling.
SAFETY AND HIGH EFFICIENCY
  • Safety travelling speed limiting device in the mast. Travelling speed will automatic lower when fork height reaces 5M.
  • Full hydraulic steering system makes turning easy and flexible.
  • Adopts hydraulic brakes for two front wheels and electric brake for driving motor, offering simple operations for travelling and braking.
  • Integrated design of driving and steering system without chain transmission, avoids chain fall-off caused by chain transmission.
EASY MAINTENANCE
  • Battery changing available through two methods :
    • Side-way battery changing by trolley.
    • Automatic push-out and pull-in function with a simple battery handle controller.
  • Bolt-fixed back cover is easy to open for daily maintenance.
OPTIONS
  • Joystick controller.
  • EPS system.
  • Height selection and height position system.
  • LCD display and camera (LCD for cold storage available).
  • EX explosion-proof type.
For further information regarding any model in RUYI's range, please contact:
Mr. Chu Jiang
Vice President
NINGBO RUYI JOINT STOCK CO., LTD.
Tel: +86-571-87153626, 87153634
Fax: + 86-571-87153628, 87153638
E-mail: sales@xilin.com/ ruyi@xilin.com
Website : www.xilin.com
Click here to view Ruyi's Shopfront
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
