NEW LCD IGNITION SYSTEM FROM KEYTROLLER
- 23 Oct 2003 ( #130 )
Dunham Instruments and KEYTROLLER, INC. announce the release of their new forklift and equipment safety device; the KEYTROLLER LCD keyless ignition-Model 501 blue-backlit LCD screen.
OSHA regulations require checklists be completed at the start of every shift. Now you can automate this checklist with the KEYTROLLER LCD. The LCD screen shows the operator programmable items (daily, weekly and monthly) that he must check pass or fail. Fail means the vehicle must be now started and cleared by a supervisor or mechanic.
The LCD screen also allows an operator to view all settings and gives a supervisor immediate access to recent events like shock/abuse, speeding, over temperature, oil pressure, "sleeper", maintenance due, hour meter, speed % limit, % of memory used and operator name.
KEYTROLLER LCD comes standard with RFID tag capabilities. This gives three levels of security that are selectable: 1) RFID enabling; 2) Key code enabling, or; 3) both to start the vehicle.
This new Model 501 is a comprehensive safety system for equipment. The system prevents untrained operators from starting the vehicle, makes abusive operators accountable for speeding and damage, monitors engine conditions and shuts down the engine as programmed.
Event downloading with filtering and graphing can be accomplished wirelessly, by infrared or by direct connection to a RS232 serial port. New CYBERKEY option can download multiple vehicles with just one data key. Over 8000 events can be stored between downloadings.
Installation is simple and can be done on any internal combustion or electric vehicle.
KEYTROLLER LCD is available through qualified forklift and equipment dealers.
For more information see www.keytroller.com or contact Dunham Instruments on 03 9876 4784 or email info@dunhaminstruments.com.au.
