Li-ion technology for Cat® electric counterbalance trucks
- 3 Sep 2020 ( #990 )
Cat® Lift Trucks has introduced the option of lithium-ion batteries on its award-winning EP25-35(C)N 80V electric counterbalance forklift range.
The move is part of a scheduled programme to make Li-ion technology available on specific Cat® trucks, as soon as it becomes genuinely cost-effective for those products. To date, it has been applied optionally to a variety of Cat order pickers, pallet trucks, stackers and tow trucks, as well as 48V counterbalance models.
Will Li-ion work for you?
While the needs of most lift trucks in most applications are still met optimally by lead-acid batteries, Li-ion has become a realistic alternative in some cases. It is especially likely to make economic and practical sense in high-energy, multi-shift, 24/7 operations.
Designed to cope with intensive duties and tough conditions, Cat EP25-35(C)N electrics are highpowered, highly productive trucks which can benefit from Li-ion's cost-saving and productivity advantages. These have to be assessed against the higher purchase cost of Li-ion to determine whether the extra investment is justified in each case.
The new batteries give longer service, higher energy efficiency and greater runtime, with a more constant voltage curve which maintains high performance levels even toward the end of a shift. Further time savings result from faster charging and opportunity charging, with virtually no need for battery maintenance. Depending on the work pattern, it is possible to operate trucks continuously with no battery changes.
High productivity and driver satisfaction - whatever the battery
Whatever battery is chosen, the Cat EP25-35(C)N range boosts output by meeting all driver needs and wishes. When selecting it for a prestigious Red Dot Award, judges praised its excellent user experience and clever design.
Key features include the Cat Responsive Drive System (RDS), which seems to know how the driver wants the truck to behave at every moment and adjusts its performance mode accordingly. Intelligent curve control reduces speed in a much more natural and comfortable way than traditional cornering systems. The next-generation, dual drive, 4-wheel steering system's +100-degree rear axle rotation combines with curve control to enable tight and smooth turning. When reversing, side turns can be made without pushing back. Uniquely, this truck can also be steered using the front axle.
These advances in intelligence and agility, along with a high-comfort operator compartment and ergonomic controls, make the truck a pleasure to drive. Customers can choose from five models, which include compact and standard chassis sizes, in capacities from 2.5 to 3.5 tonnes. The Cat 'LIBAT' option can be built into new trucks or retrofitted to existing fleets using a fast and easy conversion kit.
Further information on Cat® forklifts, warehouse equipment and related services can be found at www.catlifttruck.com. See them in action via www.catlifttruck.com/videos and follow the news on LinkedIn, Facebook and Twitter.
For more information, talk to your nearest Cat lift trucks dealer or contact: Monica Escutia, Manager Marketing Communications, Tel +31 (0)36 549 4328, send an email.
Cat® Lift Trucks
Send an email
Read our Eureka magazine
Cat Lift Trucks
Hospitaaldreef 29, 13th floor
1315 RC Almere
The Netherlands
Cat Lift Trucks
