KEYTROLLER RELEASES "SMART" IGNITION SYSTEM
- 9 Oct 2003 ( #128 )
The inexpensive KEYENABLER system uses a wireless relay instead of a standard starter relay. Each trained operator receives his own input code. When the code's accepted, the device lights up and the START button can be pushed - wirelessly enabling the starter relay. Now the vehicle's key (or a button that replaces the key) will start the vehicle.
Vehicles can NOT be "hot-wired" and stolen because the starter relay MUST be enabled before the vehicle will start. A mechanic's code can disable other operator codes while the vehicle is under repair, preventing untrained operators from starting the vehicle and safeguarding against theft.
Model 700 includes the keypad and wireless relay. The Model 701 is a more comprehensive safety system, which includes event monitoring. Downloading of these time/date/operator/vehicle stamped events is accomplished by direct connection to a PC or with the new CYBERKEY option, which can download multiple vehicles with just one data key. Over 2000 events can be stored between downloads.
Installation is simple and can be done in only a few minutes on any internal combustion vehicle. KEYENABLER is available nationwide through qualified forklift, equipment and boat dealers and sells for under AUD500 plus installation and GST.
For more information visit www.keytroller.com or contact Dunham Instruments on 03 9876 4784 or email info@dunhaminstruments.com.au.
