First Class Recycling with Bolzoni Auramo Bale Clamps
- 8 Dec 2016 ( #799 )
Bolzoni Auramo Recycling Bale Clamp, Model B-W
Bolzoni Auramo is well known for its expertise in paper handling and waste bale equipments with a wide choice of models, capacities, arm configurations and openings, to satisfy the handling requirements in the logistic chain.
To come up with the best solutions, Bolzoni Auramo is closely co-operating with the professionals in each sector. Among the European paper districts, the fourth in importance is based in Tuscany, Central Italy, and of course Bolzoni Auramo is actively co-operating with the paper manufacturing, recycling and logistic industries in the area.
Along many years, Bolzoni Auramo has a successful co-operation with a well-known Tuscany recycling company, with an eco-friendly approach and a special taste for clean working environment.
For its plant, this company has chosen the Bolzoni Auramo waste paper bale clamp model B34W. The company is managed with high quality standards and the Bolzoni Auramo clamps are perfectly supporting the handling applications.
The logistic management is very important: every day several trailers are loaded. Different kind of recycling bales are handled in the plant, with care and precision. With the help of specific machineries, the operator has to precisely separate the materials, which are mainly composed by cans, arriving from super markets, by paper and card board, and by cotton rags. They are then sorted and bales are compacted again to be loaded in to the lorry. Working in a clean environment is paramount.
Bolzoni Auramo recommended to adopt the B-W recycling bale clamp model, which is specifically designed for heavy-duty handling of waste paper, plastic, metal and other recycling material bales.
Bolzoni Auramo Recycling Bale Clamp, loading operation
Bolzoni Auramo Recycling Bale Clamp, special plastic insert
With capacities ranging from 1600 to 4200 Kg, this clamp is the ideal choice for all waste handling operations. All clamps in the range provide a high level of clamping force assuring safe bale handling.
The profile frame is in strong steel and its structure is very rigid, in a single piece double "T" profile. Cylinders and hydraulics are well protected by a front plate shield, keeping good visibility all around the clamp frame. Arms are directly welded to the sliding profiles, with special reinforced elbows.
As standard supply, replaceable wear bars are welded under the frame and the arms, providing additional wear protection. For this specific handling case, Bolzoni Auramo proposed a slightly modified clamp, with special lower plastic material extruded bar. The bale clamps are now able to gently follow possible sliding friction on the floor.
For more information on Bolzoni Auramo products, please visit: our website www.bolzonigroup.com and send an email, or contact the nearest Bolzoni Auramo representative.
Bolzoni Auramo is a Bolzoni Group brand.
For more company and product information, please:
Click to view the BOLZONI AURAMO ShopFront
