Bolzoni Auramo Heavy-Duty Lift Tables for the printing industry
- 25 Jul 2019 ( #933 )
Bolzoni Auramo lift table fitted to a printing machine.
Uteco Converting SpA, one of the world leaders in the production of printing machines for flexible packaging applications, has selected Bolzoni Auramo as supplier of lift tables to equip its machines.
Uteco is an international group, based in Colognola, Verona, Italy, which offers innovative solutions through a wide range of flexographic and rotogravure printing machines. These high-tech tailored machines can be equipped with a lift table.
In this specific application Bolzoni Auramo designed a scissor lift table to be fitted as equipment on printing machines, with clear ergonomic advantages in terms of operator safety and time optimization.
Bolzoni Auramo is one of the largest worldwide manufacturers of scissor lift tables.
Used as loading bays, as connection between different stages, in conveyor systems, packaging and weighing systems, automatic internal handling plants, for feeding of processing machinery of paper, wood and steel plants, scissor lift tables represent the best solution for the manual load handling, in full compliance with the European standards with regards to functioning, cost saving, safety and health of the operator during work.
Ergonomic working station in the sheet metal working; Feeding of processing machinery in the plastic industry: Lift Table with PVC bellows to prevent trapping between scissors and safety handrails to avoid accidental falls.
Since the cooperation started in 2008, the volume of supplies has reached remarkable levels and continues through the years with an increasing amount of units.
Aluminum safety bar, safety clearance between scissors, safety check valve, low voltage control box hold-to-run type, maintenance hinged bars for safe operation.
All Bolzoni Auramo lift tables include following technical features:
  1. Aluminum safety bar, stopping descent of the platform in case of contact with obstructions
  2. Safety clearance between scissors to prevent trapping during operation
  3. Self-lubricating bushings on pivot points
  4. Single acting hydraulic cylinders equipped with drainage
  5. Safety check valve to stop the lift table lowering in the unlikely event of a hose break
  6. Hydraulic power pack inside the table provided with relief valve against overloading and compensated flow valve for controlled lowering speed
  7. Electric equipment controlled by electronic system, with transformer and thermal protection.
All Bolzoni Auramo lift tables comply with European standards and in particular with the Machinery Directive 2006/42/CE and Safety requirements for lift table EN 1570-1.
The long collaboration with Uteco Group testifies to Bolzoni Auramo's lift table, having high performance levels, with great attention to the operator's safety and health.
Heavy-duty lift table for forklift trucks maintenance.
For more information on Bolzoni Auramo lift tables, please visit our website and contact us by email, or contact the nearest Bolzoni Auramo representative.
____
Bolzoni Auramo is a Bolzoni Group brand
