Battery Equaliser
- 9 Oct 2008 ( #381 )
Battery Equaliser Australia Pty Ltd has been providing quality products since our founding in 1997. Our mission is to provide support to businesses that are serious about implementing cost effective measures in battery maintenance, protection and reliability.
We believe the best way to achieve this goal is to work closely with our customers to ensure the best results at all times.
Battery Equaliser Australia Pty Ltd is also concerned with the ongoing problems associated with the environment. By using Battery EqualiserTM you can help reduce hazardous waste in land fills. Reduced gassing decreases the amount of dangerous airborne lead and sulphuric acid released into our environment, particularly in the work place.
Battery EqualiserTM is a liquid additive. It is formulated to extend the life and performance of any new and used vented lead acid battery by means of electrochemical reaction.
Battery EqualiserTM is the Number One tested and proven industrial liquid battery treatment.
All Vented Lead Acid Batteries Respond to the Patented Formula of Battery EqualiserTM.
Battery EqualiserTM
  • Promotes longer running times....Less down time on recharging.
  • Breaks down the sediment which causes internal resistance thus the electric current can flow unhindered
  • Helps batteries stay healthier
  • Promotes up to 40% reduction in gassing volume. Less gassing means lower maintenance and a safer, cleaner environment.
All lead acid batteries build up harmful sediment which prevents the free flow of current between the positive and negative plates. Because these plates have been strained so much in trying to accept current and delivering it through the sediment, they become brittle and buckle and eventually collapse.
The active ingredients of the Battery EqualiserTM formula break down the sediment and return it to solution. The formula permeates the weakened lead and strengthens it with a special alloy suited for this purpose - equal voltage, equal amps and equal specific gravity in each cell.
Originally, this formula was part of a graduate research project. Today, sales extend to more than thirty countries around the world. Blending, Bottling and Technical Support are handled from Australia, South Africa and the United States. There is more worldwide documentation on this product than all other battery additives combined.
Battery EqualiserTM can be used in:
  • All Flooded Lead Acid Batteries
  • Standard Non-Sealed Batteries - Cars, Trucks, Motorcycles, Airplanes
  • Deep Cycle Batteries - Marine, RV's, Solar, Golf Carts
  • Traction Batteries - Forklifts, Floor Scrubbers
  • Electric Vehicle Batteries - Cars, Buses, Electric Carts
  • Standby Power - UPS and BES Backup Power Supplies
  • For further information contact:
    PO Box 267, Eastwood NSW Australia 2122
    email: sales@batteryequaliser.com.au
    Click here to visit the Battery Equaliser ShopFront
