LED Lighting Solutions for Material Handling: TYRI’s BASEline Range
- 11 Sep 2025 ( #1247 )
Selecting the right work light for material handling machines is about more than just brightness. The output, beam pattern, durability, and cost need to match the specific demands of each machine and its operating environment. TYRI’s BASEline range delivers on all counts, providing a cost-effective line-up of LED work lights built to our rigorous standards.
Why BASEline Delivers More for Less
When every machine in your fleet needs reliable lighting, costs can add up fast. That’s why TYRI’s engineers set out to create a range that delivers the performance you expect at a price that works for your bottom line.
Through innovative design and streamlined production, BASEline lights deliver ease of assembly and efficient manufacturing without compromising TYRI’s trademark quality. Every model delivers exceptional light output, industry-leading durability, and EMC Class 5 compliance.
The result is a tough, high-output LED light that performs shift after shift while keeping costs in check. For fleets moving from halogen to LED, the savings are even greater, with lower maintenance and longer service life as standard.
From compact warehouse forklifts to the biggest yard trucks and port handlers, BASEline lets you standardise lighting across your entire operation — ensuring consistent performance, simplified maintenance, and a professional, unified look.
A Range Designed for the Job
With multiple lumen options from 700 to 2,800 effective lumens, and a choice of square or round housings with flexible mounting options, the BASEline range offers solutions to suit a wide variety of material handling applications. Every model is designed, built, and tested to TYRI’s high standards, including IP69K and EMC Class 5 compliance, ensuring consistent, reliable performance even in the most demanding conditions.
Models for Every Material Handling Role
BASEline S1
The original model and a reliable compact option in 700 or 1,100 effective lumens. Ideal for standard warehouse forklifts and smaller equipment.
BASEline S1 Diffused
Produces soft, glare-free light, perfect for confined operator environments where visibility must be balanced with comfort.
BASEline R1 Swivel
A round version of the S1 with adjustable mounting for flexible positioning. Available in 700 or 1,100 effective lumens.
BASEline R2 Swivel
Delivers 2,800 effective lumens for heavy-duty applications such as outdoor yard trucks, telehandlers, and large mixed-use machines. Includes a swivel bracket for easy adjustment.
BASEline S2
The newest addition to the range. Producing 2,000 or 2,500 effective lumens, it is designed for big material handling machines working in expansive yards, ports, or other outdoor environments where higher light output is essential.
Customisation for OEM Branding
For manufacturers, select BASEline models can be customised with your brand colour and/or logo. This enhances brand recognition in the field and helps build long-term aftermarket loyalty.
Whether your machines operate in a confined warehouse or challenging outdoor spaces, the BASEline range offers a cost-effective lighting solution that meets the demands of the material handling sector.
Contact us for more information or to book a demonstration.
Get in touch with TYRI Lights
TYRI Lights
+44 (0)... Show
Engine Shed Lane,
Skipton,
North Yorkshire BD23 1UP
United Kingdom
TYRI Lights
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
