ZAPI YALE MR16
Hello Friends!
I'm having a problem yale mr16.o EPS works 3 or 4 days and re-enters in short, all hydraulic functions work except the function of lifting, lowering this ok! (hydraulic this ok)
also'll need the wiring diagram of the MR16 yale.
grateful for comprehension
hugs
DiDomenico
  • Posted 23 Nov 2012 23:48
  • By didomenico
  • joined 23 Nov'12 - 14 messages
  • RS, Brazil
AAPEE Hello!
defective lifting already solved. The defect was MHYRIO module.
just do not know why the EPS is short-circuited after 3 or 4 days of use.
grateful
  • Posted 27 Nov 2012 00:22
  • By didomenico
  • RS, Brazil
not lifting is mostly lift interupt with zapi handset turn off.eps possible first check reach wire and coils +witch code?
  • Posted 25 Nov 2012 02:20
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Hello Friends!
on the lifting of MR 16, already decided, the module was mhyrio faulty resistor and mosfet open at exit 7 of the same.
Now I'm worried because I do not know if the EPS will work long, someone would know why the EPS come easily shorted?
would have any permanent solution for this? (short circuit power EPS \ AC ZAPI)
very grateful for the information
DiDomenico
  • Posted 24 Nov 2012 10:21
  • By didomenico
  • RS, Brazil
