ZAPI SMART ANTENNA
DOES ANYBODY HAVE ANY EXPERIANCE WITH ZAPI WIRE GUIDANCE SYSTEMS.... STARTED TO USE THEM RECENTLY........DONT NO HOW REALIABLE THEY ARE
  • Posted 10 Jan 2007 03:03
  • Discussion started by DAMO
  • DUBLIN, Ireland
up up and away
THIS IS THE FOURTH RETRO FIT WITH THIS ZAPI SYSTEM SO FAR SO GOOD UNTIL TODAY..... FITTING INTO MAGAZINERS / SWITCH ON WHEEL CENTERS...STEER MOTOR STARTS OSSILATING THEN ALARM..STEER SENSOR KO.... LOOKS LIKE A FAULTY EPS ??????
  • Posted 11 Jan 2007 06:17
  • Reply by DAMO
  • DUBLIN, Ireland
up up and away
ok damo. system i know is on hyster vna trucks. i think they have used it for 7 or 8 years. feedback pot on them tells controller when steer wheel is straight and compares it to signal picked up from wire via the aerials. if pot is not set right it the controller fights to keep truck straight and jumps off line. i recon your proximity switch must work the same.
  • Posted 11 Jan 2007 05:18
  • Reply by kevin_k
hi there kevin
in this system there isnt a pot used.....
instead theres a band on the drive motor
and the pot is replaced with a proximity switch
  • Posted 10 Jan 2007 06:39
  • Reply by DAMO
  • DUBLIN, Ireland
up up and away
zapi wire guidance is very reliable and accurate when set up correctly. usually let down by feedback pot misalignment and damage to aerials. nothing major.
  • Posted 10 Jan 2007 06:13
  • Reply by kevin_k
edition #1235 - 19 June 2025
Ncn 110TH
Ncn 110TH 2023
SMV (Konecranes) 33-1200C
