Yale GLC070VXNVRE085:
yale trans issues
HELP!!! I HAVE A YALE GLC070 THAT HAS CODE 524223-1. (FWD/REV PRESSURE LESS THAN COMMANDED) TRUCK MOVES ABOUT 5FT IN EITHER DIRECTIONS AND CODES OUT. I'VE CHECKED VOLTAGES ETC AT PRESSURE SWITCHES AND ALSO REPLACED PRESSURE SENSORS WITH NO LUCK. ALSO REMOVED SOLENOIDS AND CLEANED, STILL NOTHING. ANY HELP WOULD BE GREATLY APPRECIATED....
  • Posted 1 Jan 2015 07:51
  • Discussion started by liftman_11
  • Kentucky, United States
Showing items 1 - 15 of 22 results.
I received this same error code (524223-1) on a Yale GLC120. Our forklift would start and run, but if moved even 5 feet forward or reverse it would shut down. In another post here on Forklift Action the official trouble shooting procedure for this error is provided and its first recommendation is to verify that the transmission fluid level is not low. I checked the trans fluid on mine and indeed it was very low. I filled with Universal Tractor Trans-Hydraulic fluid (recommended for our unit) and the error code had disappeared and the forklift began running fine again.
  • Posted 9 Oct 2021 06:25
  • Modified 9 Oct 2021 06:26 by poster
  • Reply by TKO5855
  • Wisconsin, United States
I only guessing but there is a possibility that the charge pump has a seal that has broken down allowing air into the system pump pressure should be 200 lbs/in might be a problem with relief valve, should be able to check it with pressure gauge.
Regards Nero
  • Posted 13 Jan 2015 05:50
  • Reply by NER045
Yes I checked the voltages and they are as you said. Customer needed a truck so this one was sent to shop to be repaired. I hooked my quad gauge to ports and it wouldn't even budge. Customer now has loaner until trans is repaired. Also noticed trans fluid is full of bubbles. Wondering if there's internal bad seal or if it's something else internal.
  • Posted 11 Jan 2015 01:50
  • Reply by liftman_11
Hi liftman,
Let's go back to the sensors you say you checked the voltages at the sensors but you did not say what they were, with the sensors disconnected you should have 5volts with the ignition on, with the sensors connected and back probing the connector check the voltage ignition on. You should have a reading 0.5 volts or there abouts.
Do you have these readings.
It just seems strange to me that both direction solenoid so would fail together.
Recheck your voltages and come back to us.
Regards Nero.
  • Posted 10 Jan 2015 21:22
  • Reply by NER045
PROPORTIONAL VALVES CAM IN TODAY, I INSTALLED, CLEARED CODES AND ATTEMPTED TO CALIBRATE. NO CHANGE. STILL SAME ISSUE. DOES ANYONE KNOW WHAT IM SUPPOSE TO GETTING OUT OF THE TISS AND TOSS SENSORS. ANY HELP IS GREATLY APPRECIATE. ABOUT TO DRIVE ME CRAZY..........
  • Posted 9 Jan 2015 06:20
In forward code 524225-1. In reverse code 524223-1. I removed fwd and rev solenoids and put 12v to both. Neither are working. I have both ordered. Will update if this fixes.
  • Posted 7 Jan 2015 07:06
What code does it give? Is it doing the same thing if you try forward and it codes out, clear code, and then try reverse? Same code?
  • Posted 7 Jan 2015 06:35
  • Reply by mrfixit
you need to replace the proportional valves on the transmission control valve. they work together so need replaced together.
  • Posted 7 Jan 2015 05:12
  • Reply by kevin_k
I've check enable valve and all is good there. When it travels, it's like a new truck. Pulls great. But codes out after 10-15ft. Any other info would be great. Thanks
  • Posted 7 Jan 2015 04:05
Ok. I'll remove and chk. The truck will travel 10-15ft or so before it codes out.
  • Posted 6 Jan 2015 23:32
You can take the enable valve off and energize it with 12 volts. Listen for click and see if the spool moves. You can install it, start machine, sit on seat, and see if it is getting power.
  • Posted 6 Jan 2015 23:04
  • Reply by mrfixit
I removed it and cleaned it. Didn't see anything out of ordinary. And seems to be working as should. Any checks to do on it that you know of? Thanks in advance.
  • Posted 6 Jan 2015 12:06
Did you check the trans enable solenoid valve? It looks like the F and R valves, right rear corner of the valve body.
  • Posted 6 Jan 2015 11:34
  • Reply by mrfixit
yes, full throttle through entire process. ive attempted multiple times. any suggesttions?
  • Posted 6 Jan 2015 07:50
That is forward 1 valve pressure low- calibration fail. Are you full throttling the engine during calibration? The engine should be at full throttle during the entire process.
  • Posted 6 Jan 2015 04:33
  • Reply by BREWSKI
edition #1234 - 12 June 2025
Ncn 85TH
Ncn 85TH 2014
Terberg YT220
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Load Lifter 2414-8G
Flesherton, Ontario, Canada
Your Focus
