yale trans issues
HELP!!! I HAVE A YALE GLC070 THAT HAS CODE 524223-1. (FWD/REV PRESSURE LESS THAN COMMANDED) TRUCK MOVES ABOUT 5FT IN EITHER DIRECTIONS AND CODES OUT. I'VE CHECKED VOLTAGES ETC AT PRESSURE SWITCHES AND ALSO REPLACED PRESSURE SENSORS WITH NO LUCK. ALSO REMOVED SOLENOIDS AND CLEANED, STILL NOTHING. ANY HELP WOULD BE GREATLY APPRECIATED....
  • Posted 1 Jan 2015 07:51
  • By liftman_11
  • joined 1 Jan'15 - 15 messages
  • Kentucky, United States
Showing items 1 - 20 of 22 results.
I received this same error code (524223-1) on a Yale GLC120. Our forklift would start and run, but if moved even 5 feet forward or reverse it would shut down. In another post here on Forklift Action the official trouble shooting procedure for this error is provided and its first recommendation is to verify that the transmission fluid level is not low. I checked the trans fluid on mine and indeed it was very low. I filled with Universal Tractor Trans-Hydraulic fluid (recommended for our unit) and the error code had disappeared and the forklift began running fine again.
  • Posted 9 Oct 2021 06:25
  • Modified 9 Oct 2021 06:26 by poster
  • By TKO5855
  • joined 4 Jun'16 - 9 messages
  • Wisconsin, United States
I only guessing but there is a possibility that the charge pump has a seal that has broken down allowing air into the system pump pressure should be 200 lbs/in might be a problem with relief valve, should be able to check it with pressure gauge.
Regards Nero
  • Posted 13 Jan 2015 05:50
  • By NER045
Yes I checked the voltages and they are as you said. Customer needed a truck so this one was sent to shop to be repaired. I hooked my quad gauge to ports and it wouldn't even budge. Customer now has loaner until trans is repaired. Also noticed trans fluid is full of bubbles. Wondering if there's internal bad seal or if it's something else internal.
  • Posted 11 Jan 2015 01:50
  • By liftman_11
Hi liftman,
Let's go back to the sensors you say you checked the voltages at the sensors but you did not say what they were, with the sensors disconnected you should have 5volts with the ignition on, with the sensors connected and back probing the connector check the voltage ignition on. You should have a reading 0.5 volts or there abouts.
Do you have these readings.
It just seems strange to me that both direction solenoid so would fail together.
Recheck your voltages and come back to us.
Regards Nero.
  • Posted 10 Jan 2015 21:22
  • By NER045
PROPORTIONAL VALVES CAM IN TODAY, I INSTALLED, CLEARED CODES AND ATTEMPTED TO CALIBRATE. NO CHANGE. STILL SAME ISSUE. DOES ANYONE KNOW WHAT IM SUPPOSE TO GETTING OUT OF THE TISS AND TOSS SENSORS. ANY HELP IS GREATLY APPRECIATE. ABOUT TO DRIVE ME CRAZY..........
  • Posted 9 Jan 2015 06:20
  • By liftman_11
In forward code 524225-1. In reverse code 524223-1. I removed fwd and rev solenoids and put 12v to both. Neither are working. I have both ordered. Will update if this fixes.
  • Posted 7 Jan 2015 07:06
  • By liftman_11
What code does it give? Is it doing the same thing if you try forward and it codes out, clear code, and then try reverse? Same code?
  • Posted 7 Jan 2015 06:35
you need to replace the proportional valves on the transmission control valve. they work together so need replaced together.
  • Posted 7 Jan 2015 05:12
  • By kevin_k
I've check enable valve and all is good there. When it travels, it's like a new truck. Pulls great. But codes out after 10-15ft. Any other info would be great. Thanks
  • Posted 7 Jan 2015 04:05
  • By liftman_11
Ok. I'll remove and chk. The truck will travel 10-15ft or so before it codes out.
  • Posted 6 Jan 2015 23:32
  • By liftman_11
You can take the enable valve off and energize it with 12 volts. Listen for click and see if the spool moves. You can install it, start machine, sit on seat, and see if it is getting power.
  • Posted 6 Jan 2015 23:04
I removed it and cleaned it. Didn't see anything out of ordinary. And seems to be working as should. Any checks to do on it that you know of? Thanks in advance.
  • Posted 6 Jan 2015 12:06
  • By liftman_11
Did you check the trans enable solenoid valve? It looks like the F and R valves, right rear corner of the valve body.
  • Posted 6 Jan 2015 11:34
yes, full throttle through entire process. ive attempted multiple times. any suggesttions?
  • Posted 6 Jan 2015 07:50
  • By liftman_11
That is forward 1 valve pressure low- calibration fail. Are you full throttling the engine during calibration? The engine should be at full throttle during the entire process.
  • Posted 6 Jan 2015 04:33
  • By BREWSKI
after attempting calibrate once again, calibration counted down to 0 and then codes out. afterwards having code 524276-1. can anyone tell me what this is. thanks in advance.
  • Posted 6 Jan 2015 01:54
  • By liftman_11
I'll check more on Monday. Will update with any info I find. Thanks aga in guys.
  • Posted 3 Jan 2015 07:00
  • By liftman_11
when the you calibrate and stops the proces normaly it gives a code
to point witch solenoid malfunction
check the speedsensor tiss and toss in diagnostic
  • Posted 3 Jan 2015 04:18
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Oil level is good. When attempting to calibrate through the dash it gets down to about 5 secs remaining and codes out. Which proportional solenoids are you talking about. This is the first one of these I've encountered. Thanks for the replies.
  • Posted 3 Jan 2015 02:15
  • By liftman_11
this is normally a sign that the prportional solenoids need replaced , or you are simply low on oil. check the level is good and calibrate the transmission. might cure it for now
  • Posted 2 Jan 2015 20:35
  • By kevin_k
Sue Tomic Sue Tomic
Toyota 3FD100
UN Forklift FGL35T
Toyota 3FD100
UN Forklift FGL35T
Lift Tek Elecar
