Yale GLC050LX(pre VX) Mil, check engine light on
Have a Yale GLC 050LX trying to clear the MIL light, Manuel says to start engine 4 times and then on the fourth time let run to clear miL light after five seconds press accelerator pedal To floor ,tried this combination several other combinations several times unable to clear the light anybody have any experience with this truck?
  • Posted 7 May 2019 12:07
  • By steppednit
  • joined 18 Oct'13 - 50 messages
  • Tennessee, United States
Hi normally disconnect the battery and open the switch over nite and reconnect nex day and all is ok if you have any sensor is damage come on again try sometimes work
  • Posted 9 May 2019 14:22
  • By armando_g
  • joined 11 May'18 - 48 messages
If the code does not clear, it means the code is still active. You will need to find out what the code is.
  • Posted 7 May 2019 22:15
  • By BREWSKI
edition #1235 - 19 June 2025
GemOne
