Yale forklift model ERP16VTSWB/2011, 48 volts baterry , Cap- 1440 kgs
Any help about the fault code description. Because both traction and
lift is not working but fault is coming in the panel when you switch on.
Thanks,
Rolly
  • Posted 23 Nov 2014 03:30
  • Discussion started by rolly
  • Manama, Bahrain
rollbes2003@yahoo.com
Hello guys,
When i switch on spanner is appearing to the display with a no. at the top 12836. The pump is working properly but the traction is moving very slow forward and backward. Then when you press the accelerator for 1 min. fault code 29456 is appearing.
The manual brake is already release and the parking brake is disappear while pressing the accelerator switch. please help to find out the description of this fault.
Thanks,
Rolly
  • Posted 26 Nov 2014 05:22
  • Reply by rolly
  • Manama, Bahrain
Thanks swoop this is the no appearing in the display, ok i will
check the 3 curtis controller and come back you.
Thanks,
Rolly
  • Posted 24 Nov 2014 16:05
  • Reply by rolly
  • Manama, Bahrain
12836 doesn't look like any status code i've seen on these machines.
are you sure that is not the hour meter?
look on the controller and see if it has an led light
see if it is flashing in any sort of sequence.
the led will be either on the top of the unit or near the harness plug on that end of the box.
  • Posted 24 Nov 2014 14:32
  • Reply by swoop223
Good evening Swoop,
The fault code coming in the display is 12836, before the lift is working but when we change new battery this fault is coming
both traction and lift is not operating the handle stock.
Please help,
thanks
Rolly
  • Posted 24 Nov 2014 02:19
  • Reply by rolly
  • Manama, Bahrain
look on the dash display
the fault code displays there
what is it?
  • Posted 23 Nov 2014 14:39
  • Reply by swoop223
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
edition #1229 - 8 May 2025
