Yale forklift glp050lxnuae087
I have no start does not crank can jump at starter it starts and runs fine. has a can bus systemn , had dash remanufactured and a new ecu installed still, will not attempt to crank fuses and relays are all good also all grounds ckecked anybody have an idea what I am missing?
  • Posted 26 Sep 2019 06:26
  • Discussion started by firefighter55
this system is a canbus , so the bad thing there are no wires to ignition switch uses a magnet reads thru back of dash thanks again
  • Posted 27 Sep 2019 04:38
  • Reply by firefighter55
Do you have volts going to the Ignition Switch ?
If voltage is present, then you might have to replace it.
Check the Neutral Start Switch for volts & resistance.
  • Posted 27 Sep 2019 04:03
  • Reply by LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
