Yale Fault Code Cause
Fork hydraulics levers do not initiate the pump to start. Fault codes 207, 208 and 240 are displayed. Any help is sincerely appreciated. We can see what the codes relate to, we are looking for likely causes. Thanks again.
Model# ERP040THN36TE082
  • Posted 13 Mar 2014 11:10
  • Modified 13 Mar 2014 11:11 by poster
  • By m_rush
  • joined 13 Mar'14 - 2 messages
you most likely will get more and better answers/opinions if you start your own thread, rather than "hijack' a thread, especially since this thread is about electric Yales, and you have a diesel powered sitdown. now to your question,,,
Is this " pilot operated hyd lever" a finger tip control? if so you may have to adjust the center position of the lever. or replace the lever assembly.
  • Posted 12 Jun 2014 07:44
  • Modified 12 Jun 2014 07:48 by poster
Please help I have a Yale fork lift gdp35. Model 2007 has a fault code of hyd interlock , it has a pilot operated hyd lever
  • Posted 12 Jun 2014 05:40
  • By mustafa_a
  • joined 8 Jun'14 - 12 messages
  • West bank, Israel
check the battery
make sure it is filled and fully charged and has no problems in any of the cells
  • Posted 15 Mar 2014 14:21
  • joined 23 Mar'12 - 3,693 messages
Co worker found one of the microswitches at the valve body was shorted, replaced and no longer displaying a 208 fault. Now it displays a 207 fault "Lift Interrupt".
Any help is appreciated.
  • Posted 15 Mar 2014 06:35
  • By m_rush
