Yale ESC040ACN36TE008:
yale error codes
Help
error codes
65527,65299,29456,4098
  • Posted 3 Mar 2016 03:13
  • Discussion started by gen113
  • Kentucky, United States
Hi Brewski, how can I get the manual por this forklift? could you provide it to me ?
  • Posted 1 Sep 2018 13:15
  • Reply by levy_m
  • Honduras
LRMP
Have you checked for shorts and grounds to frame? With no can signal the truck should not move. What is your battery voltage doing when loaded?
  • Posted 25 Mar 2016 23:36
  • Reply by BREWSKI
The truck is coding out when plugging. Any help ?
  • Posted 17 Mar 2016 00:09
  • Reply by gen113
Thanks
  • Posted 15 Mar 2016 05:46
  • Reply by gen113
You need to check the can loop. 65527 is no signal on can loop. This will cause numerous other codes like you are seeing.
  • Posted 5 Mar 2016 03:26
  • Reply by BREWSKI
