Yale ERCO40
Anyone worked on these trucks much? Having a problem getting the battery indicator to read correctly. Parameters are set to specs. Always reads low.
  • Posted 17 Dec 2008 04:01
  • By ronnie_s
  • joined 17 Dec'08 - 2 messages
  • Kentucky, United States
Model-- ERCO40AGN48TE082
Right now the resistance comp is set at 8 and the bat voltage selection is at 186. Earlier when I was playing with the #'s on resistance comp, I would see no change in bat meter. Thanks!
  • Posted 17 Dec 2008 06:14
  • Modified 17 Dec 2008 06:15 by poster
  • By ronnie_s
We'll need more of the model # to help you out fully.
On the GE's, you can play with the 'internal reistance compensation' to get the BDI reading closer.
Be careful, though, as you can get the unit to over-discharge the battery....
  • Posted 17 Dec 2008 05:20
  • By mike_n
  • Alberta, Canada
