yale code 12833
model-erc0665vgn36te088
s- a968n10745m
code - 12833
  • Posted 19 Oct 2016 00:41
  • Modified 19 Oct 2016 00:42 by poster
  • By jamie_b
  • joined 19 Oct'16 - 2 messages
  • Kentucky, United States
also 11511 standard
  • Posted 5 Jun 2023 02:00
  • By ACER
  • joined 22 Mar'23 - 2 messages
  • Quebec, Canada
ACE
Where you able to get into the diagnostics through the display? You can check for voltage drop across the line contactor. This code indicates that the controller is seeing the battery voltage below set minimum.
  • Posted 15 Nov 2016 01:04
  • By BREWSKI
We have had controller checked and the battery is good. Anyone have anymore information leading to this fault code. Thanks in Advance for the help.
- Mike
  • Posted 12 Nov 2016 09:39
  • By MikeR
  • joined 25 Oct'16 - 2 messages
  • Illinois, United States
Default is 55555. If that does not work you will need Yale software to access the password.
  • Posted 25 Oct 2016 23:18
  • By BREWSKI
Does anyone have the passcode to get into the truck? we have check controller wiring and battery.
  • Posted 25 Oct 2016 10:16
  • By MikeR
See my answer above.
  • Posted 25 Oct 2016 08:20
  • By BREWSKI
Any info on this code.
Thank you Phil
  • Posted 25 Oct 2016 06:30
  • By phil_r
  • joined 9 Apr'10 - 21 messages
no I don't have password , I have bveen a lil concearned with the battery , in the last few months
  • Posted 19 Oct 2016 01:50
  • By jamie_b
DC Bus low. Check the motor/motor controller wiring. Check your battery voltage. Do you have a password to get into diagnostics?
  • Posted 19 Oct 2016 01:23
  • By BREWSKI
