Hi,
I have a E25B with no operators manual or service manual. It was received by my company as is. The working hydraulics have no voltage to the micro switches. I can apply voltage to wire 1P3 on the power module for the hydraulic motor and all functions will work. Steer and direction work fine. Fuses are checking good also. Does anyone know the power flow for the working hydraulic circuit?
Thanks. The battery is charged, but the meter indicates a low charge.
The truck was made by Linde (Baker) in the US and is there is no Linde (Europe) equivalent.
The battery discharge indicator is equipped with lift interrupt which shuts down the mast functions once the battery goes below a certain voltage. There is a circuit card that controls it. Either the card or meter are bad or the battery needs charging.
It's not receiving a voltage signal on the #1 wire at the motor control module. I traced the wire to the steering column. Looks like it comes from the hour meter / battery monitor. Had to leave to work on another piece of equipment at that point.
Ser# 2658-0527
What is the series of the truck?
336, 386 (it's shown in serial No)?
