Won't start
I did service on a DPN30. Replaced the usual, fuel, air, oil filters. Ran unit back to work area no problems.
Just before leaving customer said it wasn't running good and trouble starting. I got on it and it started, ran but getting like a burning plastic(maybe) smell. Ran awhile, then parked it. Tried restarting, nothing. Cranks great, won't start. Checked fuel filters, checked fuel to cylinders, getting pressure at each cylinder, will not start. Fuses tested good. Oil level good.
So weird, ran great before servicing and right after then shortly nothing.
  • Posted 1 Apr 2021 22:55
  • By Joebob
  • joined 14 Apr'18 - 22 messages
  • Virginia, United States
Joe Watkins
Ok now i understand.
  • Posted 4 Apr 2021 22:44
  • Modified 4 Apr 2021 22:44 by poster
  • By Justus
  • joined 23 Aug'20 - 37 messages
  • Finland
Not sure about the quality of their fuel.
It is at a mining facility, everything is dirty, always.
  • Posted 4 Apr 2021 22:40
  • By Joebob
Joe Watkins
Must be something wierd now... Never had To change injektors so early... Is the fuel clean what they use? ??
  • Posted 4 Apr 2021 00:33
  • By Justus
  • Finland
It was around 7800 hrs.
  • Posted 4 Apr 2021 00:27
  • By Joebob
Joe Watkins
Wov... Ok... How many hours driven?
  • Posted 3 Apr 2021 20:38
  • By Justus
  • Finland
Thanks for your reply, it appears it's fuel injector malfunction, the customer said they've had 6 other lifts do the same.
  • Posted 3 Apr 2021 07:28
  • By Joebob
Joe Watkins
I got 10 years experience for cat trucks but never happened nothing like you have. One possible is if there was something in fuel tank. when you pump air out of the system after filter chance, fuel bubble inside tank. so if fuel is contaminated, problem is clear. check filter is there anything inside.
  • Posted 3 Apr 2021 04:20
  • By Justus
  • Finland
Maxlion FB35LI
Terberg RT403
