Wont start
I have a Linde model H40D, the lift will not start. When the key is turned on all the lights come on like they are suppose to even the back up beeper works. Battery also tested good. When turn on around to start lift nothing. Lift does not try to start in any way. Any suggestions?
  • Posted 11 Sep 2014 04:22
  • By cgarner1979
  • joined 13 Dec'13 - 24 messages
  • Alabama, United States
Their is a large 40 amp fuse, not located in the fuse bank. check brake switch, had switch blowing fuse the other day
  • Posted 24 May 2015 06:12
  • By edward_m
  • joined 11 May'15 - 111 messages
Looking like it is the starter after all. Thanks for all the help.
  • Posted 12 Sep 2014 04:55
  • By cgarner1979
Make sure the seat switch is activating properly and that the parking brake is set. Verify whether or not it has an Engine shut down system and if so is there something there. Finally after you do all that and you are still stymied, call the authorized dealer who can probably help you out.
  • Posted 12 Sep 2014 00:26
  • By chris_t
  • joined 27 Jul'07 - 13 messages
First thing I would check is all the fuses and relays.....check to see if your getting voltage to the start terminal on the starter.
  • Posted 11 Sep 2014 05:11
  • By kevin_t
Mitsubishi Logisnext FD25T5M
Tusk 350CGH20
VETTER Forks, Inc.
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
Tusk 350CGH20
