wont move, no control lights
model: ERC065ghn48te084
serial no: A908N07914F
We just brought this from an auction. Beacon and head lights work.
Battery volt 48.9v.
Fuses good.
Wont move forward, reverse, forks wont tilt or go up or down.
Control panel wont light up showing charge or codes.
Parking brake and seat switch work.
No master switch.
Removed steering column covers, found they had the two wires going to the ignition jumped together with a loose wire. No wires going to ignition cylinder.
Need some help on where to go from here. No manuals or wiring diagrams.
Thanks
  • Posted 15 Aug 2017 06:53
  • By riley_m
  • joined 15 Aug'17 - 1 message
  • Northwest Territories, Canada
check the battery gate switch
truck wont run if that is not made
also there is a diode block inline with the control circuit in the control panel at connector J17 that may keep truck from powering on correctly.
  • Posted 15 Aug 2017 11:38
  • Modified 15 Aug 2017 11:43 by poster
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
Toyota 8FGU25
Flesherton, Ontario, Canada
Toyota 02-8FD30
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
