Wont go into gear
R1st off this truck is for disaster relief in North Carolina. Desperare situation. Reppinstalled the mast on a d110.after customer shipped to us with mast off. Now unit wont go into gear. Indicator say BA on dash in fwd or rev and N in neutral. We pulled it to move it running in gear and it started to work properly. But BA. Status still on. Ran for 5 min with no issues
Set air park brake and released it.now it failed again.and wont work by pulling it now.this
  • Posted 12 Sep 2018 21:04
  • By vince
  • joined 12 Sep'18 - 1 message
  • Illinois, United States
Vince
That sensor will be located on the transmission likely near the filter rather than on the Differential as mentioned above. The cab can be tilted over to allow better access. When tilting cab assure the mast is tilted fully forward.
  • Posted 13 Sep 2018 03:24
  • By tom_p
  • Alberta, Canada
BA fault indicates differential oil pressure loss. Check the wiring to pressure sensor on drive axle and fluid level, wiring may have been damaged or disconnected when mast was removed.
  • Posted 13 Sep 2018 03:11
  • By tom_p
  • Alberta, Canada
Crown RR5225-30TT321
SMV (Konecranes) 4531CC5
Hyster
