Atlet URF:
Wire Guidance problems
Hi -
I have 2 Atlet wire guided URF forklifts. One of them is having problems getting on the wire. I think the sensor may be bad. Does any one have any suggestions where I can get a sensor or troubleshoot this problem? The manual that came with the lift does not have a section on the wire guidance. The problem may lie in the connector that connects to the servo as well. But I can't find any part numbers. Any help is appreciated. Thanks
  • Posted 24 Sep 2013 23:22
  • Discussion started by hunter_w
  • Tennessee, United States
I wished I had joined the discussion forum sooner, I would of had an answer for you. You probably already found the solution to your problem. If you run into any other problems I can sell you parts or I can assist you with any trouble shootings.
  • Posted 5 Jan 2015 14:30
  • Reply by GUANAJUATO
  • Illinois, United States
If it is a factory installed option your local Nissan dealer. Atlet is owned by Nissan/Unicarriers.
  • Posted 25 Sep 2013 00:05
  • Reply by Partsguy5
Combilift Ltd
Dubuque, IA, United States
Louisville, KY, United States
Load Lifter 1056H
Flesherton, Ontario, Canada
Terberg YT182-4X2
edition #1228 - 1 May 2025
