Will not stay on.
Hi, whenever I turn the key the unit starts for a split second , I can hear the main contactor click but quickly opens and the unit just beeps. Any hints as to what can cause this.
It also doesn't want to operate in base mode.
  • Posted 1 Aug 2014 04:15
  • By EuroTech
  • joined 1 Aug'14 - 5 messages
I checked the motors with a continuity test and it was fine, but does anyone know what the acceptable ohms should be for these motors?
  • Posted 26 Aug 2014 22:20
  • By EuroTech
Hi, does anyone know if the service manual is available for the wav50-118.
  • Posted 14 Aug 2014 21:32
  • Modified 14 Aug 2014 21:34 by poster
  • By EuroTech
often the brushes are not seated correctly on new motors
remove motor and check each brush is correctly seated
you read the error code from right to left?
right most led is one,
second from right is 2
third from right is 4
fourth from right is 8
each one doubles
add up all the illuminated leds
if in fact the code is the same and the new motor is good then the controller is the only other component
  • Posted 7 Aug 2014 16:13
  • Modified 7 Aug 2014 16:16 by poster
  • By crownie
  • Victoria, Australia
OK, Replaced Motor to get rid of open motor circuit error but I'm still getting the same code is there another component inline that would course the same error code...||... Wav50-118
  • Posted 7 Aug 2014 06:21
  • By EuroTech
hey crownie am i missing something here? im thinking its code 18 inhibit or code 72 which doesn't exist.
edit: yup code led 4 and 5 not 4 and 7 like i read somehow... lol spot on crownie, left drive motor open.
  • Posted 2 Aug 2014 21:03
  • Modified 2 Aug 2014 21:05 by poster
  • By stam
fault code 24
from memory open circuit drive motor
switch service panel to push then push a few inches, switch back to drive and retry key
when unit powers up raise platform to gain access to drive motors
  • Posted 2 Aug 2014 12:34
  • By crownie
...l..l.
l = lit, battery charger plugged in
  • Posted 2 Aug 2014 07:06
  • By stam
I tried to push the unit but will no luck, I have eight LED number 4 and 5 stay "on"with key "on" does anyone know the error code ??
  • Posted 2 Aug 2014 05:23
  • By EuroTech
check battery volts under load..
  • Posted 1 Aug 2014 20:15
  • By stam
check these posts
add http here ://www.forkliftaction.com/forum/thread.asp?trid=11685
well i can't find the post where i listed the common faults
  • Posted 1 Aug 2014 16:15
  • Modified 1 Aug 2014 16:16 by poster
  • By crownie
There will be a code displayed in a series of, led lights left hand side of operator console, try place in push, push it two feet and try key on again.
  • Posted 1 Aug 2014 08:18
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
ATEX MIRETTI GROUP
Miretti Explosion Proof Systems for Material Handling: for over 50 years, "Ex Atex Safety in Explosive & Hazardous Areas".
Terberg RT223
Tusk 350CGH20
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
