what have change do I all to go at hyster forten truck of montrol pendaal to hand versneling?
what have change do I all to go at hyster fortens truck of monotrol pendaal to a direction switch
it is een hyster
model H3.5 ft
L177B27919G from 2009
best gerards michel
  • Posted 16 Feb 2009 02:47
  • Modified 17 Feb 2009 04:06 by poster
  • Discussion started by michel_v
  • noord holland, Netherlands
hi, i'm trying to fix mine as well. mine is quite old, but i cant seem to be able to losen the pedal itself so i can adjust the switch. pls can you tell me how to losen the pedal, does it come apart at all? you really sound like you know what you're saying. pls call me if u can. 214 771 5965
  • Posted 24 Jun 2014 13:02
  • Reply by momo_p
it will invalidate any warrenty on your truck if you modify it. go through your local dealer and you,ll be ok.
  • Posted 17 Feb 2009 06:07
  • Reply by kevin_k
I all redy bay een nieuwe pendal and DIRECTION SWITCH
what have change do I in the computer???????????????????????????????????????
  • Posted 17 Feb 2009 06:05
  • Reply by michel_v
sorry for the found oneself information which I have given
  • Posted 17 Feb 2009 04:08
  • Reply by michel_v
not that easy with a fortens truck. you need to get a downloaded file from hyster (dealer only) to change the program in the truck ,so it know,s what input to look for. changing pedal and fitting switch is easy bit.
  • Posted 17 Feb 2009 03:51
  • Modified 17 Feb 2009 03:52 by poster
  • Reply by kevin_k
Hi Michel
If I understand you rite you have a hyster with a monotrol foot pedal (forward and reverse switched by the foot pedal) that you want to convert to a direction switch if so it shouldn't be a problem Hyster used 2 types of monotrol foot pedal the early type had 1 switch which was in forward or reverse (no neutral position) on the later foot pedals there are 2 switches (forward and reverse) because regulation specified that the direction switch must have a neutral position. In either case all you need to do is identify the three wires (forward, reverse and common) which are connected to the direction switch or switches at the foot pedal and route them to the direction switch. If you need help identifying the wires (6 and 8 forward and reverse and 15 common) I can help if you tell me which controller is in the truck.
WHEN YOU CONVERT FROM A MONOTROL TO A DIRECTION SWITCH YOU MUST REMOVE THE DIRECTION SYMBOLS FROM THE FOOTPEDAL AS IT WILL CAUSE CONFUSION AS TO WHICH WAY THE TRUCK WILL TRAVEL AS IN IF A DRIVER USED TO A MONOTROL FOOT PEDAL DRIVES THE TRUCK HE MIGHT PRESS FORWARD ON THE FOOT PEDAL BUT IF THE DIRECTION SWITCH IS IN REVERSE THE TRUCK WILL TRAVEL IN THE OPPOSITE DIRECTION.
If you need more help let me know.
Regards Shane
  • Posted 16 Feb 2009 07:37
  • Reply by controlelectric
  • Shropshire, United Kingdom
Honeywell announces collaboration Charlotte, NC, United States
June 24-27, 2025 - Lima, Peru
August 1-3, 2025 - Coimbatore, India
September 16-18, 2025 - Dar Es Salaam, Tanzania
Architect Gustave Eiffel originally submitted his design for the Eiffel Tower to Barcelona but the city rejected it for aesthetic reasons. As we know, he had more success in Paris, however, his plan was far from popular at the time.
ROYPOW
